b18 or 20 for turbo....?
Old Jan 25, 2004 | 09:18 AM
swaplighter's Avatar
Default b18 or 20 for turbo....?
i currently have a b18c..(bored .30 with eagle rods and srp 9.5:1 pistons) skunk2 valvetrain in the head...ive been trying to scrounge up enough for turbo, havent quite gotten there yet.
the b18c build-up turned crappy with blow-by. i just picked up a b20b for free. (motor was neglected and had a bad knock.) needs rebuilt anyway...
stay with the b18 block or b20 for turbo set-up? sleeved of course.
Old Jan 25, 2004 | 09:36 AM
turbo96wr's Avatar
Default Re: b18 or 20 for turbo....? (swaplighter)
was up b18c more REVS then b20.
Old Jan 25, 2004 | 09:39 AM
Default Re: b18 or 20 for turbo....? (turbo96wr)
thats what people are telling me..is the b20 better for all motor?
Old Jan 25, 2004 | 09:55 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swaplighter &raquo;</TD></TR><TR><TD CLASS="quote">i currently have a b18c..(bored .30 with eagle rods and srp 9.5:1 pistons) skunk2 valvetrain in the head...ive been trying to scrounge up enough for turbo, havent quite gotten there yet.
well, if you gonna sleeve, then use the gsr block. And for the hot setup you can use the crank out of the b20 and use it in the gsr block...
Old Jan 25, 2004 | 02:08 PM
Default Re: b18 or 20 for turbo....? (mmuller)
what is the advantage of the crank? longer stroke? are the rods the same length? why is the b18c block so much better?
Old Jan 26, 2004 | 09:00 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swaplighter &raquo;</TD></TR><TR><TD CLASS="quote">what is the advantage of the crank? longer stroke? are the rods the same length? why is the b18c block so much better?</TD></TR></TABLE>
yeah, the b20 crank has longer stroke, no the rods are not the same, you need to use b20/b18ab rods
B18a/b B20: 137mm
B18c: 137.9mm
swaplighter
Jan 26, 2004 07:08 PM
swaplighter
Jan 25, 2004 10:55 AM
AzNjL427
Jan 22, 2004 12:36 AM
Bowen
Oct 13, 2003 06:22 AM
builtB20turbo
Oct 12, 2003 06:23 PM
