Could this problem be the distributor?
Old Jan 25, 2004 | 07:45 AM
JDMBB2's Avatar
Default Could this problem be the distributor?
ok well my prelude wont start and it is not getting any spark. i have checked every connection every fuse and even swapped in another ecu that i had and still nothing. so this is what i figured out. i swapped in another ignition coil and plug wires that i got off one of my friends, and still nothing. so i was thinking maybe a short some where. well,i checked to see what all was getting power and the coil is getting power and the distributor is getting power but after the distributor there is nothing left to check is thier. but i took off the distributor cap and everything is fine and the rotor is spinning when i bump it so now broken timing belt. please help me!
Old Jan 25, 2004 | 07:49 AM
hondatim's Avatar
Default Re: Could this problem be the distributor? (jdmh22lude)
the ignitor inside the distributor could be bad. Pretty common issue. Just do a search on no start or no spark. I know I have detailed out the diagnostic procedure to a couple of guys in tech forum on this problem
Hope this helps
Old Jan 25, 2004 | 07:53 AM
thehondaguru's Avatar
Default Re: Could this problem be the distributor? (hondatim)
yeah probebly the igniter, but you will have to buy it from honda they are like 90 bucks and I had the same problem, the igniter fixed it.
Old Jan 25, 2004 | 09:17 AM
JDMBB2's Avatar
Default Re: Could this problem be the distributor? (95 lude)
well my friend has a 97 h22 could i borrow his distributor mine is from 94 h22 just so i make sure that is the problem before i spend money on a new one
EsCo_EsCo
Sep 29, 2008 08:25 AM
ILuvMyJdmDc4
Nov 27, 2007 04:43 AM
HoNdAmAn29
Sep 4, 2004 08:49 AM
girlieracerk
Dec 18, 2003 10:12 PM
