hondata ??????
Old Jan 24, 2004 | 06:25 PM
Cole D's Avatar
Default hondata ?????? old problem solved
I have the hondata 3b system and I recently installed the clutch switch and now my redline is all screwed up I called myself setting up the full throttle shift and the 2 step but its all f*cked up my car now has a 6500 rev limit I have tried to raise it like they show you on the hondata website but it doesn't work any suggestions ?
Chris
Modified by Barney Ruble at 10:56 PM 1/26/2004
Old Jan 24, 2004 | 07:06 PM
JrCRXHF's Avatar
Default Re: hondata ?????? (Barney Ruble)
do you have the datalogger too...if so hook a laptop up and read what the data logger shows for your max rev. can you change your 2 stage the launch setting.
Old Jan 25, 2004 | 06:46 AM
Cole D's Avatar
Default Re: hondata ?????? (JrCRXHF)
I have a laptop and I tried to hook up the hondata but I don't get anything I'm pretty sure I'm doing something wrong is there anyway to reset the settings I need to take to my hondata dealer 80 miles away just don't have time
Chris
Old Jan 25, 2004 | 08:48 AM
JrCRXHF's Avatar
i know what you are saying i am that far from my tuner too...um you could call him up the only thing i can say is that the 4 pin connector that goes to the inside of the ecu might have got pulled i have never had this problem with my hondata. you could pull the power on the ecu and see if that helps or call you dealer and ask him how to reset all your launch stuff...did you try pulling the launch switch clip off the ecu. where did you hook up your launch switch.
Old Jan 25, 2004 | 10:02 AM
hondatim's Avatar
Well, when you turn key to on (without engine running) does light on interface light up solid? If not, could have communications issue with interface to ECU (again, via 4 wire connector into ECU)
Old Jan 25, 2004 | 07:01 PM
Cole D's Avatar
Default Re: hondata ?????? (hondatim)
I haven't unplugged the ecu yet I'll try that and my red flashes 1 time when I start the car then its a solid light
Barney Ruble
I put the launch control where the cruise control used to be and the red button is on the dash
Modified by Barney Ruble at 9:54 PM 1/26/2004
Old Jan 26, 2004 | 01:53 PM
Cole D's Avatar
I downloaded hondata instructions today and I'm going to reset the switch
Thanks for the help guys
Barney Ruble
TurboHatchB16
Apr 6, 2009 12:57 PM
boostdvic
Aug 6, 2008 09:01 AM
turbotime
Oct 10, 2005 11:56 AM
2K_TEG
Feb 7, 2003 07:50 AM
Brian_92GSR
Nov 15, 2001 01:58 PM
