taking out the rivets on the TPS?
Old Jan 24, 2004 | 08:08 AM
htownteg's Avatar
Default taking out the rivets on the TPS?
can someone tell me how to take out the rivets that are holding the tps to the throttle body? i want to put a new tps on thanks
Old Jan 24, 2004 | 08:19 AM
doublejz's Avatar
Default Re: taking out the rivets on the TPS? (htownteg)
dremmel, or just get a drill the rivets
Old Jan 24, 2004 | 08:20 AM
hondatim's Avatar
use drill with bit just big enough to drill off tops of heads.
However, a lot of TP sensors used tamperproof bolts, not rivets. So you may want to try small hammer with chisel and lightly tap these heads in counterclockwise rotation to loosen them and then they should back out.
It's been a while since I have modified throttle body for replacing TPS so I could be wrong...
I mean I have slept since then.
Old Jan 24, 2004 | 08:31 AM
South sol's Avatar
file the head of the bolt/screw to a slot so you can unscrew the bolt/screw with a flat-head screwdriver
Old Jan 24, 2004 | 08:42 AM
IN VTEC's Avatar
Dremel cut-off disc to cut a slot into the bolt/washer. Then use a standard screwdriver to remove them.
Old Jan 24, 2004 | 08:48 AM
htownteg's Avatar
im going to use southsol and invtec's method thanks everyone damn i wish i had a dremel
mindless head
May 31, 2015 07:38 PM
Evasion
Aug 20, 2010 05:37 PM
bbrian
Feb 13, 2006 08:40 AM
gsr98teg
Feb 18, 2004 04:07 PM
Vp Special K
Apr 8, 2003 07:58 PM
