3M Windo-Weld = Good
Old Jan 23, 2004 | 04:47 AM
Ef Whore's Avatar
Default 3M Windo-Weld = Good
Last week I filled two old front/rear engine mounts with this stuff. It is a urethane windshield adhesive that cures up tough. After letting them cure for a week I installed them last night as I froze my ***** off.....unbelievable difference. No engine movement whatsoever, no engine rocking starting the engine, and now I can really have fun with the Centerforce DF, second gear lights the f%&k up as well as third.....if I really bury third I can get a scuff out of fourth. Anyways I reccomend this to anyone looking to put all their power to the wheels, regardless what year car/motor you are running. I left the side mounts stock since they were fine and they really dont control much movement anyway. It is $12 for a normal caulk-size tube. Allow a week to cure to be safe.
Old Jan 23, 2004 | 02:37 PM
machine4321's Avatar
nice ..i plan on doing this when it warms up .....i hear that 2 days is enought time to cure ...with somewhat warmer temps
Old Jan 23, 2004 | 11:46 PM
Ef Whore's Avatar
Default Re: (machine4321)
I let mine cure in my garage, which is heated. After two days it was decent, but after the week it was close to rock hard. It takes a while for the inside to fully cure. I figured why risk it after 1-2 days and have the caulk bust apart when I bang second....so I just waited.
Old Jan 23, 2004 | 11:50 PM
Cottonwoodz's Avatar
Default Re: (Ef *****)
Bye, Bye crank bearings...........
Old Jan 24, 2004 | 07:33 PM
oh come on your not gonna beat that agin ...how would stiffer motor mounts have an affect on crank bearings.......i guess every guy with a eg/h22 will have crank bearing problems as well ....the 3m is a polyuretane...same as just about any mount kit you would buuyy for a swap ....i will agree on the crank pulley cause it make perfect sense as to why vibration would come into play ...but thats a direct linkt to the crank it self ....not trying to be a **** but i find it very hard to belive ....
Old Jan 25, 2004 | 12:43 PM
special_edition's Avatar
Default Re: 3M Windo-Weld = Good (Ef *****)
How bad is the virbation after you stiffen up the mounts? Does the whole car seem to rattle more?
Old Jan 25, 2004 | 05:17 PM
preluda92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">oh come on your not gonna beat that agin ...how would stiffer motor mounts have an affect on crank bearings.......i guess every guy with a eg/h22 will have crank bearing problems as well ....the 3m is a polyuretane...same as just about any mount kit you would buuyy for a swap ....i will agree on the crank pulley cause it make perfect sense as to why vibration would come into play ...but thats a direct linkt to the crank it self ....not trying to be a **** but i find it very hard to belive ....</TD></TR></TABLE>
The softer motor mounts allow a little more cushioning during hard shifts. It's the Stunnarific 6-puck clutch on a bolt on motor barking them into 3rd shifts that will mess up the bearings. It puts a huge strain on the crankshaft when it's suddenly jarred from 7k to 5k. But, those lighting fast shifts are proabaly good for in upwards of .1 seconds in the 1/4 mile so... do what you want.
Old Jan 26, 2004 | 03:57 AM
ok that i could understand....
its really amazing when you think about how hard we are on these motors....and just how strong they are...stock or not ..
so i guess in a sence ..a light flywheel would reduce he amount of long term damage to the bottom end ...
lil kid
Honda Civic (2001 - 2005)
Jul 22, 2008 02:11 AM
Ef Whore
12
Oct 4, 2007 05:15 PM
meno19
14
Aug 2, 2006 03:03 AM
vettman
Jul 20, 2005 12:46 PM
pre92ludesi
Apr 16, 2002 05:47 PM
