compression testing procedure info needed
Old Jan 22, 2004 | 02:49 PM
gregv's Avatar
Default compression testing procedure info needed
want to perform a compression test on my DOHC ZC in my '91 Civic,
as it is currently running on three cylinders. From what I understand,
I have to disable the fuel pump and possibly open the throttle body
butterfly all the way. Is this correct? If so, is the best way to disable
the fuel pump by removing a fuse? And does the butterfly have to be
opened fully?
any info appreciated
greg v
Old Jan 22, 2004 | 05:37 PM
jdmhatch94's Avatar
Default Re: compression testing procedure info needed (gregv)
-take out ecu fuse or unplug (kills the fuel pump and igniton).....
-extra step i take unplug the dist plugs...
-take out all sprak plugs and wires
-hold throttle wide open
-crank over at lest 5 times
the readings should be with in 10% of each other ,hope that helps ya.......
Old Jan 22, 2004 | 06:19 PM
gregv's Avatar
Default Re: compression testing procedure info needed (jdmhatch94)
thanks bro
alot more helpful than the local Honda dealer....
cheers
4thgenner
Feb 21, 2006 07:51 AM
Aphelion
Feb 13, 2005 10:14 PM
jbiggsSE
Jul 16, 2004 06:41 AM
gregv
Feb 15, 2004 12:04 AM
