n00b question: lightweight flywheel = different idle?
Old Jan 22, 2004 | 08:09 AM
98cwitr's Avatar
Default n00b question: lightweight flywheel = different idle?
I was wondering if a lightweight flywheel makes your car idle differently?
Old Jan 22, 2004 | 08:19 AM
yoshi234's Avatar
I shoot brides
Default Re: n00b question: lightweight flywheel = different idle? (98cwitr)
it didn't make a diff on mine.
Old Jan 22, 2004 | 08:23 AM
thk's Avatar
thk
Members Only
Default Re: n00b question: lightweight flywheel = different idle? (yoshi234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoshi234 &raquo;</TD></TR><TR><TD CLASS="quote">it didn't make a diff on mine.</TD></TR></TABLE>
It's just Tweakmeister.
The idle didn't change on mine.
Old Jan 22, 2004 | 08:25 AM
BudMan's Avatar
Yes, it can at least until the cpu has figured out something is a little different in there...
I experienced a quick drop in rpm on the motor for the first few days when coming up to a stop/idle. It was enough to kill the motor. It's been fine ever since.
that's my .02 - on my personal experience (clutchmasters fw/clutch/pp)
1GreyTeg's Avatar
Default Re: n00b question: lightweight flywheel = different idle? (thk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">
The idle didn't change on mine.</TD></TR></TABLE>
Mine either.
Old Jan 22, 2004 | 08:36 AM
thk's Avatar
thk
Members Only
Default Re: n00b question: lightweight flywheel = different idle? (BudMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it can at least until the cpu has figured out something is a little different in there...
that's my .02 - on my personal experience (clutchmasters fw/clutch/pp)</TD></TR></TABLE>
Might as well add that mine didn't change but my setup consists of Toda FW/OEM clutch disc and PP.
Old Jan 22, 2004 | 08:54 AM
137's Avatar
137
U got a spoon flywheel but I wish I went with the toda someone said it had counterweights or some bs in the middle of it...
But im not knocking it at all.
Old Jan 22, 2004 | 09:58 AM
mstewar's Avatar
only for a couple days til the ECU got it's business in order..
doesn't have that sudden drop in RPMs in my car anymore..
Old Jan 22, 2004 | 12:43 PM
ITR764's Avatar
Default Re: n00b question: lightweight flywheel = different idle? (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Mine either.</TD></TR></TABLE>
or mine... toda here
Old Jan 22, 2004 | 12:56 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Mine is fine, I went with an excedy 9.5.
Old Jan 22, 2004 | 01:59 PM
Bbasso's Avatar
Old Jan 22, 2004 | 05:57 PM
Tweakmeister's Avatar
Hahaha, no mine didn't change either, I hadn't plugged in the IACV and mistakenly took the high idle as "less load" ...
Old Jan 22, 2004 | 06:31 PM
JjuuN R's Avatar
if it does change the idle to where it's uncomfortable to you, resetting the ECU will probably do the trick
crxdriver1991
Sep 22, 2006 01:25 PM
darockstar
Mar 10, 2006 05:00 PM
DC2 Mang
11
Feb 8, 2006 08:28 AM
chitownrida
Dec 9, 2005 02:24 PM
petrv
Sep 25, 2003 06:11 AM
