Thermostat Q
Old Jan 21, 2004 | 07:48 PM
VTECisSeXY's Avatar
*insert here*
Default Thermostat Q
First off, yes... I have searched
Now to the question. I have a 1st gen b16a in my crx and I want to replace the thermo in it (no heat atm and im praying this is why). Which thermo. should I get? thanks!
Old Jan 21, 2004 | 09:35 PM
bossman032's Avatar
Default Re: Thermostat Q (VTECisSeXY)
running without a themo will not cause ur car not to have a heater.
some else is wrong I am running without no themo car takes a **** load off time to warm up.. but when its warmed up it gives normail heat
Old Jan 21, 2004 | 11:25 PM
JonGP4's Avatar
well just depends on where u live, that guy is in ohio, where as ur in cali.. big temp difference.. his motor probalby never gets hot enough to make heat.. where as in cali the temps are much warmer ur car runs hotter..
i'm in TX, and i run without a thermo.. i have decent heat, but on the really cold night.. i think it was like 20 degrees (yeah don't laugh) the heater didn't seem to be very warm.. so i can only imagine it would be weigh less at even lower temp
go with a stock Honda one.. the aftermarket ones always crap out
Old Jan 22, 2004 | 02:28 AM
VTECisSeXY's Avatar
*insert here*
Default Re: (JonGP4)
well, like i said... im praying this is the reason... and the thermostat is the cheapest to replace atm.
Old Jan 22, 2004 | 05:20 AM
slywfbpsi's Avatar
Default Re: (VTECisSeXY)
I replaced mine with a autozone brand haven't had any problems.
Old Feb 1, 2004 | 08:14 PM
accord91h22's Avatar
Default Re: (slywfbpsi)
I have the same question. Which one will work in the older b16? Or are all b series thermostats the same?
Old Feb 4, 2004 | 07:23 AM
Default Re: (accord91h22)
I found the answer. Thx anyway. Get one for a 99-00 si or the b16 del sol.
Old Feb 4, 2004 | 07:49 AM
b16_madman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">I replaced mine with a autozone brand haven't had any problems.</TD></TR></TABLE>
I used a Medium temp. one for a 90-91 Integra I believe.
No thermostat? Umm, why not? Weight savings...haha...jk
Old Feb 4, 2004 | 08:18 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Old Feb 4, 2004 | 09:02 AM
Matty.'s Avatar
OEM, of course!
Old Feb 4, 2004 | 10:06 AM
slywfbpsi's Avatar
Default Re: Thermostat Q (gumtape_deathmatch)
according to autozone, site, all b18c integras and d16z6, d16y8 civics have the same part number for thermostats, so the b16 should be the same part number as well.
Old Feb 4, 2004 | 10:19 AM
bossman032's Avatar
Default Re: Thermostat Q (slywfbpsi)
driving without a themostat will cause very bad gas mileage
unless you like bad gas mileage don't do it
the.hamburglar
Jun 15, 2008 11:27 AM
Muckman
Dec 6, 2005 08:14 AM
dustrag
Jun 17, 2004 08:11 AM
johnjw
20
May 8, 2004 07:12 PM
another civic
Mar 7, 2003 09:58 PM
