headlights out..........
Old Jan 20, 2004 | 09:01 PM
hobo79's Avatar
New User
Default headlights out..........
my 98 civic headlights are out.....they are the projector headlights and the side corner lights are on, but the high n low beams are completely OUT. went to the mechanic and he says that its sumthin to do with the wiring electrical.....he would have to take sometime to see where the problem is. he says it aint the bulbs.........i took the car cuz i needed it that day and would come back later on.
I am bout to go back tomorrow, but i was wondering what it could be and where to locate it so i can save some $.......someone help me out. (i hope this is readable)
Old Jan 20, 2004 | 10:43 PM
hobo79's Avatar
New User
Default Re: headlights out.......... (hobo79)
help???
Old Jan 21, 2004 | 05:30 AM
vtecb20coupe's Avatar
B A N N E D
when you say out, do you mean they just won't shine? and you've checked to make sure all fuses are good and the bulbs are not burnt out? all that you can do is retrace the wiring and possibly see if you've lost a connection somewhere.
Old Jan 22, 2004 | 10:12 AM
hobo79's Avatar
New User
Default Re: headlights out.......... (vtecb20coupe)
sorry, i kinda suck when it comes to electrical.....where would that be located? the high n low beams are totally out. doesnt light up or anything.
Old Jan 22, 2004 | 01:27 PM
XoUnKoWnXo's Avatar
I think that it could possible be a blown relay. You have two of them on the headlight harness. They are like black box things. There should be two of them. I would try replacing them I beleive they are only like 6 bucks a piece. But I couldn't tell you for sure.
Old Jan 22, 2004 | 02:14 PM
vtekstorm's Avatar
Default Re: headlights out.......... (XoUnKoWnXo)
bro take the harness off and just take the connector from the headlamp and connect it to the harness from the car. i got angel eyes projectors on my car and it came wit a big *** harness. i didnt even use it. and i had my projectors on for a yr wit no problems. try it that way maybe it works
Old Jan 22, 2004 | 11:11 PM
hobo79's Avatar
New User
Default Re: headlights out.......... (vtekstorm)
so it could be a harness problem as well?.....cuz the projectors have one big harness that when connected connects to both high n low beams.....so i dunno.
i think i will be adding city lights to it shortly as well if i have to get them to check my headlight prob, mite as well add the citylights
Old Jan 23, 2004 | 08:25 PM
hobo79's Avatar
New User
i am bout to pickup some 2002 maxima HIDs for my 98 civic coupe. I am wondering if it would fit directly or does it need to be retrofitted?
Old Jan 23, 2004 | 08:38 PM
vtekstorm's Avatar
i would try the headlights witout using the harness. take the connector from the headlamps and connect it directly to the connector from the car. by the way what is the brand of headlights. are they called denji? if it is take the wire harness out cuz u dont need it.
Old Jan 24, 2004 | 12:01 AM
hobo79's Avatar
New User
i dont think its denji....dont they make GLASS projectors? cuz these are plastic. BUT about the HIDs for the maxima....need to retro or can this just plug n play with a lil fiddling of the wires?
Old Jan 27, 2004 | 02:47 PM
hobo79's Avatar
New User
****!.......well, didnt get the HIDs yet, but i got the mechanic to fix my headlight problem........he said it was something to do with the wiring, relays, and he changed all the bulbs for me......******* came out to be $180...****, man i think i got ripped. What do u guys think? he said it took him almost 5 hours to figure out what was wrong.
Old Jan 27, 2004 | 03:31 PM
redlinetuning's Avatar
think you got fucked.. probably just a fuse or something.. headlight harnesses usually don't go bad unless you burned the f$ck out of it.
Old Jan 27, 2004 | 05:16 PM
vtekstorm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekstorm &raquo;</TD></TR><TR><TD CLASS="quote">i would try the headlights witout using the harness. take the connector from the headlamps and connect it directly to the connector from the car. by the way what is the brand of headlights. are they called denji? if it is take the wire harness out cuz u dont need it.</TD></TR></TABLE>
dude you got ripped off cuz i told you take out the harness and try it without the harness
Old Jan 28, 2004 | 06:57 PM
hobo79's Avatar
New User
damn man, and i usually go to him cuz i trust him.......time to look for a new mechanic then.........unless u charging me cuz he took alotta time to figure it out? etc.......
Old Jan 28, 2004 | 08:07 PM
vtekstorm's Avatar
i aint charging noone bro we were all just trying to help you out and save you the money that u spent but hey its all fixxed. reason y i told you try it witout the harness cuz my projectors came wit a huge *** harness and it looked like a mess to work wit. das y i tried it witout the harness and it works wit no problem
Old Jan 28, 2004 | 10:02 PM
hobo79's Avatar
New User
I meant unless HE was.......wasnt referring to u. sorry
How much do i expect to pay for retro fitting maxima HIDs into my civic 98 projectors? also am i getting a good deal for the maxima HIDs for $150 pickup? comes with the bulbs, ballast n wiring........
JDMin206
Lighting
Jan 10, 2012 05:28 PM
fire21
Oct 15, 2007 02:24 PM
Chewy Built !
Oct 4, 2006 08:26 PM
fathergoose
Sep 19, 2003 06:13 AM
