Is there a diff. in obd1 & obd2 Oil pump?
I want to know if buying a used 98+ would be ok or do I have to buy a new one from dealer which is an arm & a leg............
Thanx in Advance
Thanx in Advance
yes ther is a difference between obd 1 and obd 2 pumps the obd 2 pumps ahve the position for the CYP sensor and also the lower cover has different mounting holes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">yes you can, but you have to get a obd2 lower timing cover also.</TD></TR></TABLE>Have anyone tried this? obd2 pump bolts up to obd1 block w/ just the addition of the lower timing cover?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">yes ther is a difference between obd 1 and obd 2 pumps the obd 2 pumps ahve the position for the CYP sensor and also the lower cover has different mounting holes</TD></TR></TABLE>
It's the CKF sensory not CYP.
-PHiZ
-PHiZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 »</TD></TR><TR><TD CLASS="quote">yes it works just fine</TD></TR></TABLE>So an obd2 oil pump will bolt up to an obd1 block with just the addition of the lower timing belt cover......so did you guys change out the water pump, timing belt, etc. to the newer obd2 ones also (because the obd1 and obd2 parts are different) when using the new obd2 oil pump, or just kept everything else the same besides the oil pump and lower timing cover?
As everyone has said the oil pumps have the exact same mounting points (i.e. both will bolt to the same block without a problem) the difference is the '96+ oil pumps have mounting points on their outer casing for the crankshaft speed fluctuation sensor which is only needed when running most OBDII ECU's... Whenever we rebuild motors we typically just use OBDII oil pump even if the motor is going in an OBDI car, it just makes it easier if later on down the road your motor gets paired up with an OBDII ECU...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 »</TD></TR><TR><TD CLASS="quote">As everyone has said the oil pumps have the exact same mounting points (i.e. both will bolt to the same block without a problem) the difference is the '96+ oil pumps have mounting points on their outer casing for the crankshaft speed fluctuation sensor which is only needed when running most OBDII ECU's... Whenever we rebuild motors we typically just use OBDII oil pump even if the motor is going in an OBDI car, it just makes it easier if later on down the road your motor gets paired up with an OBDII ECU...</TD></TR></TABLE>Thanks for making that clear, just wondering if there was a difference in the teeth, etc. But I got it now, thanks
Damn, I just remembered too... I forgot to mention even if the water pumps for some reason have a different part number they're still the exact same... 22 teeth = VTEC pump
CivicTT
Jul 12, 2010 01:29 PM
