distributor question
am i supposed to use an accord or prelude distributor on the h23a swap into an 94 accord ?! i got an f22 and h22 dizzy but not an h23 . i am using an accord lx obd1 harness . thanks for any replies .
Modified by redxalien at 9:05 PM 1/24/2004
darn i was afraid of that . well i dont have an h23 distributor . butt i have an h22 and a f22 distributor . is it possible i can use either one of those on my h23 ?! if it is not possible how much would a new h23 distributor go for ?!
after searching for awhile . i found out that the f22 dizzy is an external coil and the h22 is an internal coil . butt what is the h23 ?! i also found out i can make a conversion from external to internal . butt still trying to find out if i can use the f22 or h22 dizzy on the h23 .
The USDM H22 and USDMH23 distributors are the SAME part. They BOTH have external coils. JDM H22 distributors are internal coil.
So if your H22 distributor is from a US H22...you should be fine. Also, the ODBI H22 and ODBII H22 distributors are DIFFERENT. You will need an ODBI dizzy.
Now, I would like to know if the F22 distributor can work. I am not sure if the SOHC and DOHC difference creates any issues.
Anyone know??
Anyone know??
use a prelude dis. only
