bad TPS?
Old Jan 19, 2004 | 12:36 PM
Hybrid CRX's Avatar
New User
Default bad TPS?
will a bad TPS make your car run like ****?
it bogs when i accelerate sometimes, not all the time.
Old Jan 19, 2004 | 01:56 PM
maxxdout's Avatar
Default Re: bad TPS? (Hybrid CRX)
yes it will make the car run poorly. You can check the TPS by referencing the signal voltage output from it. Sweep the throttle open to close. you should see a voltage change from about .5 to approx. 5 at WOT. IF not, try replacing, thats probably the problem.
mouab18c1
Engine Management and Tuning
18
Jun 3, 2010 10:57 AM
Turbo_y8
Aug 27, 2007 12:03 PM
Tronix102
Dec 9, 2004 07:50 PM
JDMCivicHatch93
Jun 17, 2003 04:18 AM
SpoolnG2
Jan 1, 2003 08:32 AM
