What is your turbo setup for your 6th gen Accord? "Searched"
Old Jan 19, 2004 | 11:45 AM
coupedup's Avatar
Default What is your turbo setup for your 6th gen Accord? "Searched"
I've searched and couldn't find that much. What setup are you using and what do you think of it? If its custom, could you post details? TIA
Old Jan 19, 2004 | 01:19 PM
notoriousB's Avatar
Default Re: What is your turbo setup for your 6th gen Accord? "Searched" (coupedup)
DRAG gen 4 kit - it is an excellent kit, I just need a better fuel management setup now. And the oil return line setup could be better...
Old Dec 7, 2004 | 09:58 PM
hotaccord243's Avatar
Default Re: What is your turbo setup for your 6th gen Accord? "Searched" (notoriousB)
where do you find the drag generation 4 kits at?
Old Dec 7, 2004 | 10:11 PM
pngfolife's Avatar
Default Re: What is your turbo setup for your 6th gen Accord? "Searched" (hotaccord243)
F-max/Turbonetics kit, 10psi, 233 whp, 209wtq, from all stock internals w/.043" head gasket, through a stock automatic transmission on 17's too.
Old Dec 8, 2004 | 12:23 AM
lowboost's Avatar
Garrett T25 turbo with Turbo specialties manifold. decent manifold, and i'm told the charge piping and all that other stuff they include in their kits fits really well. I use Emanage to tune and 440cc injectors. Factory internals and I'm running 8psi and producing 213 whp and 201lb/ft on 94 octane. Using a spearco intercooler as well.
Old Dec 8, 2004 | 04:54 AM
Turbowa's Avatar
Default Re: (lowboost)
Fully built motor with f-max/cutsom kit. Finishing the AEM EMS extras installation. Sould be tuned soon. When on e-manage and auto 15psi 324whp and 301ft/lb of torque. See what happens this time with a few different parts.
Old Dec 8, 2004 | 06:10 AM
TheShodan's Avatar
Moderator
Default Re: (Turbowa)
On the 5th Gen Accord (94-97) We did a full H22A fully built swap w/ 9:1 Compression closed deck. Since there were no kits when this was put together, the fabrication was custom using an XS Engineering GT-R sized intercooler, w/ a T04R Garrett turbocharger in an S cover. Since at the time there was no AEM EMS or Hondata available for that H22A ECU, we went with MOTEC management. Recently it was 526whp@18psi and 445ft/lbs. And this was on 19" wheels, and a Blitz body kit.
Acura_I-RS
Apr 1, 2003 05:11 PM
PUREVIL
Mar 7, 2003 08:47 PM
Regulator
Oct 31, 2002 02:41 AM
blacksheep
Jun 11, 2002 07:34 AM
acrdheadturner
Mar 6, 2002 02:18 PM
