B17A1 turbo setup
Old Jun 9, 2002 | 03:49 PM
blacksheep's Avatar
Default B17A1 turbo setup
Anybody running a B17A with turbo? I'm planning on doing this, and would like to know what hp to expect. I've been debating between all-motor and turbo, and I think turbo will make me happier. I plan to get a DRAG kit from Ben at ImportParts. I know they have a DRAG 2 kit for my car, I was wondering if they make a DRAG 3 for it yet? Could I expect 250 whp on stock internals?
Old Jun 9, 2002 | 04:07 PM
b18bturbo's Avatar
Default Re: B17A1 turbo setup (blacksheep)
i think you can push around 220 hp at around stock boost levels around 5-6psi.
Old Jun 10, 2002 | 09:22 AM
blacksheep's Avatar
Default Re: B17A1 turbo setup (b18bturbo)
That should satisfy me for the time being. But I though the DRAG kit would have me running around 7 psi on a stock setup. If this is true wouldn't I be putting out a little more whp.. like maybe 230. Come on guys.. I need some opinions and advice.
Old Jun 10, 2002 | 01:10 PM
blacksheep's Avatar
ttt.. come on guys
Old Jun 10, 2002 | 01:47 PM
DA666's Avatar
u can put down as much power as 250whp....running 7-10 psi safely
fuel setup needs to be accurate
timing will need to be adjusted
u can definetly put down 250 whp with a gsrb17a with a drag kit, im guessing fmu+inline.....? in order to run that safely i would go with a better fuel setup and hondta= 450's,550's+stock pump+hondata tuned....
im me and we'll b.s. about DA setups.
Old Jun 10, 2002 | 03:53 PM
blacksheep's Avatar
Default Re: B17A1 turbo setup (T3T4DA6)
Cool, thanks for the info. So would a Hondata Stage 2b with some larger injectors work ok? I was thinking about RC Engineering 310cc, but I'm wondering if that would be big enough. Keep the info coming.
Old Jun 10, 2002 | 10:03 PM
blacksheep's Avatar
ttt
Old Jun 11, 2002 | 07:14 AM
blacksheep's Avatar
going up
Old Jun 11, 2002 | 07:34 AM
b18bturbo's Avatar
what do you need to know about this setup.... its very similar to a gsr setup. only difference is you got the perfect rod stroke ratio....
thino
Jul 14, 2006 05:51 AM
PnkRokCountryboy
Jun 19, 2005 08:28 PM
JimmyT89
Jan 21, 2003 03:44 PM
turbo Si
Aug 19, 2002 03:59 PM
westcoaststyle
Honda S2000
14
Jan 2, 2002 05:21 PM
