b20 help ...
Old Jan 19, 2004 | 09:57 AM
theSQad's Avatar
Default b20 help ...
Ok .. so Ive never built a b20vtec ... nor do I have much expierence with this swap .. so I have a few questions .. Ive heard people use the GSR head sometimes .. with all the rods, crank and pistons from a GSR .. but we dont wanna use b18c1 parts ... we would rather use b16a2 parts .. is the distance the pistons travels less on the head of a b16 ? ( thats what ive heard ) ? and isnt that better for the motor in the long run ... ?? and would we be able to use a GSR crank with b16 pistons and connecting rods .. ?? sorry if all this sounds stupid .. like I said .. we've never attempted this swap ... any help would be appreciated
Old Jan 19, 2004 | 09:56 PM
BluePrintmfg.com's Avatar
Banned
Default Re: b20 help ... (thesqad127)
you can use the B16 pistons and just put them on the B20 rods ( you will have to shave the rods 1mm or the pistons to fit the B16 pistons on the non-vtec rods. The b16 crank will not work with the B20 rods. Just use the B20 crank you will make more power with it.
Hope this helps with your build.
Old Jan 19, 2004 | 10:14 PM
theSQad's Avatar
sweet .. hell yeah it does .. so scratch the GSR crank .. b20 crank with shaved rods and b16 pistons ... sounds easy enough ... lol ..
Old Jan 19, 2004 | 10:17 PM
mmuller's Avatar
Mad Scientist
Default Re: b20 help ... (11sec.ALL MOTOR)
You cant use pr3's on a b20 block......81mm vs. 84mm
if you want more compressionn you need aftermarket pistons
Old Jan 20, 2004 | 09:47 AM
theSQad's Avatar
what are pr3s? b16 pistons ?
Old Jan 20, 2004 | 12:06 PM
mmuller's Avatar
Mad Scientist
Default Re: (thesqad127)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesqad127 &raquo;</TD></TR><TR><TD CLASS="quote">what are pr3s? b16 pistons ? </TD></TR></TABLE>
yes
Old Jan 20, 2004 | 05:30 PM
theSQad's Avatar
so aftermarket pistons are the way to go for this build .. i assume a b16 ecu is gonna be needed ... but what about wiring harness? what harness should we use ... a b16 harness right ?
Old Jan 20, 2004 | 06:34 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesqad127 &raquo;</TD></TR><TR><TD CLASS="quote">so aftermarket pistons are the way to go for this build .. i assume a b16 ecu is gonna be needed ... but what about wiring harness? what harness should we use ... a b16 harness right ? </TD></TR></TABLE>
if you want more compression, aftermarket is the way to go.you fir the ecu, b16 spec timing and fuel programs are not going to cut it.You need to get your ecu chipped with a more agressive program ment for the b20/vtec; if not you gonna run lean.
harness b16 will do
Old Jan 20, 2004 | 07:20 PM
theSQad's Avatar
hell yeah .. thanks dude .. I know about the hi comp pistons for all motor .. im not a newb .. just dont have expierence with these motors .. this is the first time we've ever tried to build one .. !!! you helped out alot thanks dude
Deetz
Jun 5, 2017 07:01 PM
jfrase06
Nov 22, 2007 12:52 AM
LaOstha
Jul 5, 2006 05:35 PM
88 rex
Mar 13, 2003 07:29 PM
