Cost efficent fuel management options?
Guest
Posts: n/a
I'm just need to figure out some type of fuel management for a turbo kit I'm waiting to put on that I've pieced together for my EG hatch. It's a turbo off of a 02 USDM WRX, hf ported manifold and adapter, DSM intercooler, airtronics(I think thats what it's called) fuel pump, 12:1 FMU, 1st gen dsm bov. Need some help cause I'm yearning to slap this snail on my y7. I haven't installed it yet due to no fuel management yet and like my engine running
. So need some ideas on a cost efficent setups. Thanks
Guest
Posts: n/a
Just the FMU will be fine up to what point though? I don't plan on boosting over 10psi with the stock internals anytime soon so this setup will be safe? What are stock injectors good up to? I've heard up to 8-9 psi? Just don't wanna run lean. I still need to pick up some gauges(a/f, oil pressure, water temp) Anyother suggestions? What kind of programs are out for the obd1 non vtec ecus for a FI setup?
Screw you guys, I'm... going... home.
What, no mention of the afc hack or the smc hack? It is certainly better than the fmu hack. Do a search for afc, safc, s-afc, vafc, v-afc, and smc.
