Here's my setup - Any guesstimates on HP level?
Bensons Sleeved and O ring's 83mm LS block
Eagle rods and CP 83mm 9:1 Pistons
T3/T04E non-BB turbo - .48 A/R Stage 3 turbine, .60 A/R 57 Trim compressor
Tial 38mm wastegate
2.5" Turbo-back exhaust with hi-flow cat.
Hondata Stage 2b with Walboro 255 FI pump and 720cc injectors
B16 Head - stock valvetrain except 97 GSR cams (LS/VTEC)
I will be tuning to 17 PSI on 94 Octane gas. I am hoping for 350 WHP. My only concern will be the restrictive .48 A/R turbine. I would like to stop revs at about 7500, but may go to 8K if needed.
Do you guys think I will reach my HP goals? I will be happy with 300 WHP, but would really like to see 350.
Tial 38mm wastegate
yea you will get to 300 hp but to get to 350 hp I think you should get a 3" exhaust and possibly change IM if you havent already. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiBirdie »</TD></TR><TR><TD CLASS="quote">17psi you better be in the 400whp range buddy.. </TD></TR></TABLE>
I don't think the .48 turbine will allow that. It would be nice though......
you should be able to get close to 400 whp
Bottlenecks == 2.5 exhaust & turbo
Get a bigger turbo.
I was able to get 450whp on 14psi and pump gas on my car with 62-1.
Get a bigger turbo.
