Hp difference between Tial 38mm,40mm, so on
Old Mar 17, 2004 | 07:01 AM
Rod.'s Avatar
Default Hp difference between Tial 38mm,40mm, so on
Im am looking for 375-400 whp . Maybe you can correct me on how much i can look toward with my setup. Also would my delta wastegate hurt me?
83mm sleeved ls block
cp pistons 9:1
pauter rods
lighten flywheel
stock b16 head
hondata s200
injectors i sold but lookin towards (rc 750cc)
t3/t4 50 trim .60 ar
no name intercooler
i have delta wastegate right now
3" exhaust
Old Mar 17, 2004 | 07:13 AM
b18bturbo's Avatar
Default Re: Hp difference between Tial 38mm,40mm, so on (redturbocivic)
what manfiold are you running on the car and what turbo are you planningto run.
the 40mm is no longer made so you either have the choice of 38mm or 44mm vband style or 46mm
its all depends on how much exhaust gas you need ti expel to keep a certain boost level
Old Mar 17, 2004 | 07:16 AM
RyanEJ8's Avatar
Check out the info I posted in this thread. https://honda-tech.com/zerothread?id=799741
Old Mar 17, 2004 | 07:18 AM
Rod.'s Avatar
Default Re: Hp difference between Tial 38mm,40mm, so on (RyanCivic2000)
rev hard
running a garrett t3/t4 50 trim .60 ar
Old Mar 17, 2004 | 07:31 AM
b18bturbo's Avatar
tial 38mm should be fine for your needs.
Old Mar 17, 2004 | 07:42 AM
Rod.'s Avatar
Default Re: Hp difference between Tial 38mm,40mm, so on (b18bturbo)
Thanks
Old Mar 17, 2004 | 10:47 AM
JZ 97 SS 1500's Avatar
The 38 is plenty by far. If not, you can always upgrade to the turbonetics racegate which will handle alot more, and is not much more $$.
Jose
Old Mar 17, 2004 | 10:50 AM
g2turbo's Avatar
Default Re: Hp difference between Tial 38mm,40mm, so on (JZ 97 SS 1500)
Tial 38mm all the way. It will support up 600 whp with the correct spring.
Hill4589
Northeast (Sales)
Aug 13, 2010 11:13 AM
vtecguy01
Dec 29, 2005 06:42 PM
JDMCRX
Jul 22, 2003 04:22 AM
Kamin
Jan 1, 2003 07:08 PM
