3000k...bog out
as the title says i just swapped an obd0 b16 into my 91 crx.....ran great till alternator went out, changed the alternator now after 3000k rpm it boggs out and misfires....waht is the problem
stop going to 30000000 rpm's its bad for your motor!!!
if you mean 3k then it could be limp mode, check the LED on the ecu with the car on but not running.
Count the flashes, long = tens place, short = ones place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwchkypmp20 »</TD></TR><TR><TD CLASS="quote">as the title says i just swapped an obd0 b16 into my 91 crx.....ran great till alternator went out, changed the alternator now after 3000k rpm it boggs out and misfires....waht is the problem</TD></TR></TABLE>
wow, what kinda stroke kit did you use to get to 3,000,000 RPMs? Must be crazy horsepower
Seriously though, what model Rex is it? Did you have MPFI stock, if not was installed properly? More info please.
code 4 = crank angle sensor.
Turn the ignition off and remove the fuse for the ecu. Wait 10 sec and see if you get code 4. If not problem solved. You may want to check for a poor or loose wire at the distributor. If you still get code 4, you have a bad distributor.
