CHECKING ECU FOR CODES??!!
Old Nov 25, 2003 | 09:58 AM
halfNhalf-83's Avatar
Default CHECKING ECU FOR CODES??!!
Hey peoples just have a quick but important question for all. Recently i have been having some strange symptoms for my engine...and while driving over the mountain pass my ecu decided to throw a code...but i am not sure how to EXACTLY check the ecu to make it show me the code......CAN ANYONE TELL ME THE STEP BY STEP OF HOW 2 DO THIS...starting with the location of the ecu??THNX a BUNCH
Old Nov 25, 2003 | 01:02 PM
Default Re: CHECKING ECU FOR CODES??!! (SMseagren83)
can anyone help with this problem or question???anyone
Old Nov 25, 2003 | 02:25 PM
Chiovnidca's Avatar
What year and model did you say?
Old Nov 26, 2003 | 04:15 AM
JimBlake's Avatar
Default Re: CHECKING ECU FOR CODES??!! (Chiovnidca)
'92 Accord - he posted again in Tech. But I don't know how to do it on that year.
https://honda-tech.com/zerothread?id=688459
Old Nov 26, 2003 | 01:39 PM
knowtomorrow3001's Avatar
How do you check the ECU for codes on a 95?? Cause I took it to Autozone and they could find the plugin
Old Nov 26, 2003 | 01:52 PM
Chiovnidca's Avatar
Default Re: CHECKING ECU FOR CODES??!! (knowtomorrow3001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knowtomorrow3001 &raquo;</TD></TR><TR><TD CLASS="quote">How do you check the ECU for codes on a 95?? Cause I took it to Autozone and they could find the plugin </TD></TR></TABLE>
If it's a v6 model, the obd2 data link connector is behind the ashtray. The service check connector should be under/behind the glove box.
Old Nov 26, 2003 | 07:26 PM
Nick H's Avatar
New User
95 wasn't obd2...so there wouldn't be a diagnostics behind the ashtray in that year...
Old Nov 27, 2003 | 05:50 AM
Chiovnidca's Avatar
Default Re: CHECKING ECU FOR CODES??!! (Nick H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">95 wasn't obd2...so there wouldn't be a diagnostics behind the ashtray in that year...</TD></TR></TABLE>
The v6 model Accords were OBD2 starting in 1995. The DLC is behind the ashtray.
Old Nov 27, 2003 | 09:29 AM
chrisCNL's Avatar
if it is a 92 the SCS sonnector plug is on the right of the dash under the Glove compartment. It should be covered with a green cover. Look for the two pin plug that the SCS plug.
crazzymad
Sep 24, 2008 10:15 AM
-Championship-
Sep 6, 2006 05:54 PM
halfNhalf-83
Nov 26, 2003 01:55 PM
TurboRedSi
Jul 17, 2003 10:59 PM
