b18c5 motor swap soon
Old Jan 16, 2004 | 05:25 PM
GhettoR's Avatar
Default b18c5 motor swap soon
Guys,
Finally got some time off, what problems could I expect xfering the motor from one EG to another? Is there anything I should replace while the motor is out of the car, ie belts, pulleys, sensors etc?
Old Jan 16, 2004 | 05:33 PM
Kendall's Avatar
Check the condition of all the mounts as well as sensors such as the TPS. It would be easy to go ahead and replace thinks like the timing belt if you feel that it is time to do so. There's basically no set in stone response to your question, if it looks broken or worn, then replace it.
toddhunter
May 16, 2019 07:32 AM
OmgDelSol
29
Apr 16, 2013 09:30 AM
MelszEg6
Dec 23, 2008 09:57 AM
scottybfh
Sep 28, 2006 05:01 AM
CivicSwapper
Sep 1, 2006 07:41 AM
