need help just starting
Old Jan 16, 2004 | 04:19 PM
khmerb0ix7o2's Avatar
Default need help just starting
Getting a 96-00 hatchback, dont know what to do with it, I want to be hitting 13's or 12's all motor, or force induction, don't know what to do, probably gonna get a b18c1 gsr motor, if you guys have any other advices of what kind of motor should i get please tell me, I want to start building this now.
Old Jan 16, 2004 | 04:35 PM
Kendall's Avatar
Well, there are a lot of options to consider. Probably the most effective will be a b series motor with a mild turbo setup at maybe 8 or 9 pounds of boost. A B18C at 9 lbs when properly tuned should put an EK well into the 13's. With some good airflow modifications, a couple hundred pounds of weight reduction and some more boost, 12's don't seem out of reach.
Old Jan 16, 2004 | 04:49 PM
Default Re: (Kendall)
what kind of internals should I get, I know pistons about the 11:2 ratio or the 82mm whatever, but I dont know what numbers are good and what numbers are bad, is higher or lower number goods,
Old Jan 16, 2004 | 04:54 PM
Kendall's Avatar
Running anything less than 10 psi, I wouldn't worry about upgrading the internals. A stock B18C with damn good tuning can handle as high as 12 psi with no issues.
Stock bore is 81mm, you shouldn't change this if at all possible if you plan on running boost without sleeving the block.
Old Jan 16, 2004 | 05:28 PM
what about all motor, should I up grade my internals, what brands are good and for what parts
Old Jan 16, 2004 | 05:37 PM
Kendall's Avatar
Running an all motor setup you'll spend a lot more money getting the horsepower that you want. being that you are shooting for 12's then drag racing is probably what you do most often. If you plan on primarily drag racing, then I wouldn't consider all motor unless you have a budget of considerable size.
If you do go all motor, consider the Civic Type R pistons and Toda valvetrain components. Cams are pretty much up to you, and should heavily depend upon your goals.
Old Jan 16, 2004 | 05:42 PM
Kendall's Avatar
Basically what your going to have to do is:
1. sit down
2. do a lot of research
3. establish some goals
4. determine which upgrade path will best help you reach those goals
5. research that upgrade path
6. begin work
I've been researching for months and still haven't decided on what to do. While deciding though, I've been concentrating on things such as the interior, weight reduction, and next will probably be the suspension. You'll always have something to do to your car, so don't get in a hurry with the motor until you have a definate decision on what you want to do.
Old Jan 16, 2004 | 07:10 PM
yeah, my first goal is to get a gsr motor but dont know what to do next, I have no idea on like is higher or lower compression ratio is better like 11:1 on pistons or the size 83mm which is better high or lower numbers, damn got so much reseach to do
Old Jan 16, 2004 | 07:21 PM
Default Re: (khmerb0ix7o2)
when i get an engine swap, just an engien swap will i be able to drive my car, do i need anything like parts, or tuning, or temperatures, suspension, something that is bad to my car, if i just have the gsr motor in it with nothing else
Old Jan 16, 2004 | 07:25 PM
Jimmy's Avatar
Global Moderator
**** giving details...theres like 200+ topics on this...get off your lazy *** and search and btw your not going to hit 12's with <u>your</u> ''b18c1 gsr motor'' umm like we didnt know what a b18c1 is?
Like said before sit down and do some research it sound like you need lots of it.
Then after you research come back
Old Jan 17, 2004 | 07:40 AM
Kendall's Avatar
Default Re: (USDMDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 &raquo;</TD></TR><TR><TD CLASS="quote">**** giving details...theres like 200+ topics on this...get off your lazy *** and search and btw your not going to hit 12's with <u>your</u> ''b18c1 gsr motor'' umm like we didnt know what a b18c1 is?
Then after you research come back </TD></TR></TABLE>
Easy there killer. Don't wanna run the guy off now do we? j/p
Research is recommended, and yes you can run the B18C1 without any issues by just swapping it in.
DC2grape
15
Oct 6, 2010 03:11 PM
sirekhatch
Feb 23, 2007 09:21 AM
romero4
Sep 8, 2006 06:40 AM
TruePlayaz114
Oct 31, 2003 12:31 PM
DomesticRiceMobile
Jul 26, 2003 07:44 AM
