starting in the cold
Old Jan 16, 2004 | 02:24 PM
xrocket21's Avatar
Default starting in the cold
1995 gsr isnt starting since it got cold. I replaced the battery and that didnt help. Sometimes it just clicks, sometimes I can hear the starter spin without engaging the flywheel. A few times it has caught and started. Are the solenoid and starter separate? Should I try to replace that? What should I try? Connections or anything, or should I just buy a used starter? thanks. Im screwed and its been -30 all week.
Old Jan 16, 2004 | 03:21 PM
B18C2_sedan's Avatar
Default Re: starting in the cold (xrocket21)
sounds like a sticking starter. Try tapping it a few times while someone turns the key. Be careful by the way
Old Jan 16, 2004 | 05:19 PM
quik1's Avatar
Default Re: starting in the cold (B18C2_sedan)
The cold will do a lot of sh*t to your car like B18c2 said try tapping it. If your battery is left out over night in that kind of temp you will loose most of the power in your battery, this may sound extreme but try taking your battery in at night.
Old Jan 16, 2004 | 07:11 PM
xrocket21's Avatar
Default Re: starting in the cold (quik1)
sooo cold, -30 or colder 5 nights in a row just isnt cool.
serr38
Jan 15, 2010 11:01 AM
See Are X
Mar 6, 2003 10:08 PM
integranator
Jan 12, 2003 10:52 AM
