? about jdm sir II rear disk brake conversion onto eg
Old Jan 16, 2004 | 09:45 AM
vtecb20coupe's Avatar
B A N N E D
Default ? about jdm sir II rear disk brake conversion onto eg
okay , i purchased a set of jdm sir II rear disk brakes a while back for my eg. got a few questions before i attempt the install. i know that the lca's are identical to the usdm itr so i am going to swap out the lca's and use my stock eg ones so i can use my aftermarket shocks.
what brake lines, etc. will i need to complete this swap(from which car)? also, any, dohc brake booster will work, correct? any other parts that i may need? thanks.
Old Jan 16, 2004 | 10:31 AM
H23vtecEG's Avatar
Default Re: ? about jdm sir II rear disk brake conversion onto eg (vtecb20coupe)
any brake booster will work. but a gsr would be nice for your setup.
as far as brake lines there will be a rubber line separating caliper from the rest of the line. if you dont have one get an integra 94-up. other then that the whole thing is pretty easy. enjoy and good luck
Old Jan 19, 2004 | 04:55 AM
B A N N E D
Default Re: ? about jdm sir II rear disk brake conversion onto eg (H23vtecEG)
ok, which e brake cables do i need? if you've got the part #'s, that'll work as well.
Old Jan 19, 2004 | 06:16 AM
nema741's Avatar
I used the ebrake cables out of a integra for my rear disc swap.
Old Jan 19, 2004 | 07:26 AM
B A N N E D
hmmm...just thought about something.
i'm not at home right now to measure, but is the wheel pattern for the jdm eg 4x100 or 4x114.3?
Old Jan 19, 2004 | 08:10 PM
JeffS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">4x100 </TD></TR></TABLE>
Old Jan 20, 2004 | 05:06 AM
B A N N E D
Default Re: ? about jdm sir II rear disk brake conversion onto eg (JeffS)
****, got scared there for a minute.
Old Jan 20, 2004 | 06:36 AM
92b16vx's Avatar
Yea, it's 4x100, and you can get order the ebrake cables for a 92-95 Si hatch, mine were about 88 bucks for both from http://www.hondaautomotiveparts.com
Also pick up the same year/model brakelines.
Old Jan 20, 2004 | 08:13 AM
B A N N E D
ok, so using the eg si model brake lines and e-brake cables will work?
Old Jan 20, 2004 | 02:38 PM
b18blove's Avatar
the only other thing i can say is with the booster make sure you use the gsr master cylinder as well
Old Jan 21, 2004 | 10:32 AM
B A N N E D
Default Re: ? about jdm sir II rear disk brake conversion onto eg (b18blove)
ok, will do
gsr brake booster
gsr master cylinder
eg si e-brake cables
eg si brake lines?
OptxEm1
Suspension & Brakes
Jul 23, 2012 07:03 AM
cehcivic15
May 5, 2010 08:45 AM
CivicSIR20
11
Nov 10, 2009 11:54 AM
.BigSexy
Aug 10, 2004 08:01 AM
egghead
May 26, 2002 08:55 AM
