B21A1 Motor
Old Jan 16, 2004 | 07:11 AM
AlienKrOZ's Avatar
Default B21A1 Motor
Anyoen know where I get a B21A1 Motor Around Chicago, IL and where is a good place to build this motor up for boosting?
Old Jan 16, 2004 | 07:36 AM
kablamo's Avatar
Default Re: B21A1 Motor (AlienKrOZ)
dont.
build up a B20A5 instead, or a JDM B20A
the B21A1 cylinder liners aren't very durable and the engine will wear prematurely. it's probably one of Honda's worst engines. Finding one in good shape is almost impossible.
a B20A5 would be best, as the JDM B20A has higher compression...
Old Jan 16, 2004 | 07:40 AM
AlienKrOZ's Avatar
Default Re: B21A1 Motor (kablamo)
Its still not a good idea to ge teh b21 even if i build it up and resleeve everything. what about the b20b
Old Jan 16, 2004 | 10:49 AM
kablamo's Avatar
you mean a CR-V motor?
it woudln't be a straight swap that's for sure (with a B20B)... although the engine in G3 ludes are B-series, they are fairly different than the newer B series in the civics and civic based cars (integra, CRV). you can do it, but it's easiest to stick with a B20A
as for resleeving the B21A1, it's kind of a pain because it's one of Honda's first engines to use fiber-reinforced sleeves (they aren't iron) - like the NSX, H22's and S2000 engines. problem is these first gen fiber sleeves didn't have great durability and hence the problems of the B21. If you put new ones in, you'd just have a motor that would burn oil (turbo'ed) after 50k for sure.
You could put in iron sleeves i guess, but i'm not sure if those are even available. that's the thing with B21A1's, getting all the parts can be hard because it was only produced for 2 years, and not in the most common car.
whatever you do make sure you check the price and availability of all your parts...
Old Jan 16, 2004 | 05:47 PM
gsr-HF's Avatar
or better yet put a h22 in that mo'fo.
Old Jan 17, 2004 | 08:01 AM
kablamo's Avatar
Default Re: (prelude2sin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude2sin &raquo;</TD></TR><TR><TD CLASS="quote">or better yet put a h22 in that mo'fo.</TD></TR></TABLE>
sweet but hard and expensive to do right.
entirely possible though...but then no room for turbo that's for sure
Old Jan 18, 2004 | 06:45 PM
AlienKrOZ's Avatar
Default Re: (kablamo)
how are the b20b compare to the b20a cause? h22 is out of it cause its much more work.
Old Jan 19, 2004 | 12:59 AM
JohnnyTequila's Avatar
Default Re: (AlienKrOZ)
theB20B and the B20A are pretty much completely different, the B20B is more like the B16/17/18 from the newer tegs and civics. while the B20A or B21A is mainly prelude. very few similarities, like the cam gears, flywheel, and cams are quite close but i think need to be machined to fit.
also, one of the first guys with an H22 swap who i believe is on this site, has a H22 Turbo, putting somthing like 415 to the wheels in a 3rd gen prelude. pretty ******* sick too.
first off, is this going into a 3rd gen prelude at all????
if so, your best bet is the B20A5, or get a JDM B20A. but you say that you are going to rebuild it and build it for boost, well, the B20A and B21 are pretty much the same motor with minor differences. so as long as you are going to resleeve the block you doesnt really matter. and the B20B would be about as much work as the H22 to swap in because they utelize different motor mounts, and dont sit the same way as the the B20/21 A motors.
if this is going into a civic or teg or something i have a feeling that you are looking for the B20B which would be more suited for those cars and less custom work to install.
Old Jan 19, 2004 | 10:40 AM
AlienKrOZ's Avatar
Default Re: (JohnnyTequila)
for a 94 teg
Old Jan 19, 2004 | 05:12 PM
you want the B20B motor.
thats from the Honda CRV. they run pretty cheap, 800 bucks long block last time i checked on one.
Old Jan 20, 2004 | 07:04 AM
AlienKrOZ's Avatar
thsoe come around cheap
gsrteg83
Jan 30, 2013 04:01 AM
wesinls
Feb 2, 2009 06:25 PM
CivicSiRacer
May 24, 2007 12:36 PM
EtotheG
Mar 14, 2003 01:15 AM
