Throttle dwell
Old Sep 30, 2001 | 05:50 PM
2fcknfst's Avatar
Default Throttle dwell
Ok, Holley has just sent me a replacement 68mm TB with the appropriate throttle screw in it to replace my post production unit that no one can figure out how I got it.
The problem I am experiencing is the revs stay up when I get off the gas.
This is somewhat puzzling to me considering the post production unit did not do this.
I have tried to dial the throttle screw all the way in, and all the way out. No change, in either idle or dwell.
I am wondering if this has something to do with Spec b's. Do they create enough vacum to warrant extra fuel being provided?
This is puzzling. Has anyone else had this problem with any mods they have done?
Thanx in advance...
Old Sep 30, 2001 | 06:13 PM
DB2-R81's Avatar
25 Year Member
Default Re: Throttle dwell (2fcknfst)
You likely have a vacuum leak somewhere. Recheck your work!
Old Sep 30, 2001 | 07:07 PM
2fcknfst's Avatar
Default Re: Throttle dwell (DB1-R81)
Yeah, I thought about that. It is unlikely because the idle does come back to 850ish; it just takes a while to do so.
That is why I am curious...
Old Sep 30, 2001 | 09:41 PM
Big Phat R's Avatar
Sticky throttle cable/linkage?
Old Oct 1, 2001 | 08:08 AM
2fcknfst's Avatar
Default Re: Throttle dwell (Big Phat R)
No, all good. I even put a return spring on the opposing side in order to ensure the throttle plate was closing.
I cannot figure it out.
fear45
Dec 25, 2018 07:11 AM
hybridEj6
Oct 5, 2006 11:23 AM
Des9255
Oct 24, 2005 09:58 PM
Mr. JDM-GSR
Aug 29, 2005 11:33 AM
Initial DA6
Aug 29, 2002 03:24 PM
