QUICK HELP, compression values
Old Jan 15, 2004 | 06:56 PM
KUjonathan's Avatar
Default QUICK HELP, compression values
hey all, i have searched but can't find solid values for a compression test on an 89 crx si, stock, d16a6 motor. i'm consistantly getting 130,146,150,150.... ANY IDEAS where this should be?!
Old Jan 15, 2004 | 07:12 PM
RCautoworks's Avatar
Default Re: QUICK HELP, compression values (KUjonathan)
Those sound ok, the cylinder with 130 seems like its slowly drifting away from the others. When doing a compression test besides having high numbers, you want all the numbers to be close to each other.
Old Jan 15, 2004 | 07:16 PM
KUjonathan's Avatar
Default Re: QUICK HELP, compression values (90blackcrx)
right, about 75% between the lowest and the highest.... according to my manuals. But i was also intrigued by the slope. the number one cylinder? (farthest from distributor) is the 130, then 146, then the left two are 150. but i don't think its low enough to merit pulling the head to check head gaskets, etc... i dunno. I'm checking the motor out becuase i want to run it in G-stock autocross, and its got to be solid. it won't be modified, it just needs to be solid... any other ideas, anybody else? (thanks 90blackcrx!)
Old Jan 15, 2004 | 07:32 PM
Kamin's Avatar
you removed ALL the spark plugs before you tested, right? cause leakage between cylinders via a bad head gasket will give a false test.
and that 130 is a little low, add a small amount of oil to that cylinder and retest the compression, if it raises up to 150ish your rings are starting to go.
Old Jan 15, 2004 | 08:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KUjonathan &raquo;</TD></TR><TR><TD CLASS="quote">right, about 75% between the lowest and the highest.... according to my manuals. But i was also intrigued by the slope. the number one cylinder? (farthest from distributor) is the 130, then 146, then the left two are 150. but i don't think its low enough to merit pulling the head to check head gaskets, etc... i dunno. I'm checking the motor out becuase i want to run it in G-stock autocross, and its got to be solid. it won't be modified, it just needs to be solid... any other ideas, anybody else? (thanks 90blackcrx!)</TD></TR></TABLE>
Did you let the engine get warmed up before doing the test ? That can effect the results a little. Also make sure you hold the throttle wide open when doing the test to. (Your welcome )
Old Jan 15, 2004 | 09:10 PM
KUjonathan's Avatar
well, yeah, i did let the engine warm up. but get this. after testing the first time, i let the car idle for about 20 minutes (partly becuase i forgot i left it running), to charge up the battery from all the cranking. well then i turned it off, came inside, had a beer, then went back out like 45 minutes later and redid the test (was going to add a bit of oil to the suspect cylinder), but when i ran it, all cylinders were from 150-160 psi. so could it be these? :
good situation: somehow letting the motor run (mostly sits right now) blew out some nasties, maybe helped clean up the valve seats? or maybe just messed up the first test.
bad situation: says something i don't understand.
haha :
any ideas?
thanks again
Brandon Peters
Oct 18, 2015 05:37 PM
thebleek
39
Sep 13, 2008 11:21 PM
one bad dx
Jan 4, 2007 09:55 AM
b16ahatchcrap
Mar 21, 2006 05:00 PM
b20turboic
Dec 24, 2005 11:05 AM
