Compression Test help ..
Old Dec 24, 2005 | 10:44 AM
b20turboic's Avatar
Default Compression Test help ..
Hey guys checked my compression on my 84mm LS today after a year of races and got some numbers ...
This is about 9:1 compression maybe a little lower due to some head work to the combustion chambers (still LS head) ... SO the lowest maybe 8.9:1 or so but lets leave it at 9:1.
Ok from the dizzy
cyl 4 148
cyl 3 150
cyl 2 146
cyl 1 151
All done full throttle with all the spark plugs removed to check for any head-gasket problems. Also done with a cold motor.
I can not seem to find anywhere even what a B20B with 8.8:1 compression should be to even have something to compare so I am stuck asking you guys for some help.
How can I figure out what it should be or does any one happen to know about what I should be getting... I think B20's are about 150 or so but like I said I cant find it anywhere online anymore.
Any help would be great thanks guys
Old Dec 24, 2005 | 10:55 AM
Slow ass EF's Avatar
Default Re: Compression Test help .. (b20turboic)
8:1-8.5:1 compression: 150-170 psi per cylinder
8.5:1~9.5:1 compression: 170-210 psi per cylinder
9.5:1~11:1 compression: 210-275 psi per cylinder
11:1+ compression: 250+ per cylinder (highly depends on cams being used)
evans-tuning.com
Old Dec 24, 2005 | 11:05 AM
b20turboic's Avatar
Default Re: Compression Test help .. (slow *** ef)
thanks a lot man
Now I have to factor in weither or not my cams lowered my number or if the rings never sealed hahhaha
xxliljonxx1
11
Jun 4, 2012 01:47 PM
KDawg08
Mar 7, 2012 10:38 PM
So krazieY
Jul 25, 2009 09:57 PM
cornhusker
Sep 21, 2003 07:02 AM
K20 EG
Jun 17, 2003 11:26 AM
