gsr rear disc onto a ex couple of questions
the 96 ex brakes are 10.2" so yeah same size...
use 92-95 0r 94 up integra lines for the rear
yes the master cyl can stay but the pedal will be kinda spongy till like 1/2 way down till you change to a teg one...and if you wanna chance it i have one
You don't need the swap the master cylinder or the brake booster because you have an EX. The GSR front rotors are the same size as the ex fronts, but the gsr front calipers are a little bit bigger.
The GSR rears are the same as the SI rears. Your MC and booster are the same as what comes in the 99-00SI.
Use the SI rear e-brake cables. i have *heard* that the teg cables work. You will also need the 99-00SI prop valve.
btw, I did this conversion about 2yrs ago with '00SI rear discs.
first off, try this thread:
https://honda-tech.com/zerothread?id=152884
if for some reasin u cant firgure out the abundance of info, heres what i got using a SIMPLE SEARCH.
https://honda-tech.com/zerothread?id=722071
https://honda-tech.com/zerothread?id=720861
https://honda-tech.com/zerothread?id=675431
https://honda-tech.com/zerothread?id=657601
https://honda-tech.com/zerothread?id=653444
https://honda-tech.com/zerothread?id=630634
https://honda-tech.com/zerothread?id=631649
https://honda-tech.com/zerothread?id=607791
https://honda-tech.com/zerothread?id=586143
https://honda-tech.com/zerothread?id=564577
https://honda-tech.com/zerothread?id=548147
https://honda-tech.com/zerothread?id=498759
https://honda-tech.com/zerothread?id=494262
https://honda-tech.com/zerothread?id=451320
your welcome.
your welcome.
ludesrv
Oct 25, 2008 02:37 PM
chinochanginc
Dec 31, 2007 01:59 AM
Cory man
10
Feb 1, 2005 08:44 AM
