car bogs when accelerating???????
Old Jan 15, 2004 | 11:30 AM
Hybrid CRX's Avatar
New User
Default car bogs when accelerating???????
gotta gsr in my civic ...... and everything runs fine.
when i go to accelerate somtimes it like boggs, and ants to cut off. jerks the car really hard.
im thinking its the cap and rotor?
HELP!
Old Jan 15, 2004 | 11:52 AM
horror's Avatar
Default Re: car bogs when accelerating??????? (Hybrid CRX)
did you just have it put in? make sure all the grounds are connected still
Old Jan 15, 2004 | 01:36 PM
ultimatehonda's Avatar
Yes make sure the timming is to spec, and all the grounds and wires are all connected the way they should be.
Old Jan 15, 2004 | 02:10 PM
sivik2nr's Avatar
one other thing to check is your TPS sensor. I had that same problem and it wasn't even throwing a code all the time.
I could see from my S-AFC that the throttle position was jumping all around. Sometimes when i would push on the gas, the S-AFC would show the throttle reading at 0 and then all of a sudden jump to like 40, thus the jerking car. and bogging.
Old Jan 15, 2004 | 03:03 PM
-[95cxhatch]-'s Avatar
Default Re: (sivik2nr)
water in distrbutor?
Old Jan 15, 2004 | 04:38 PM
horror's Avatar
Default Re: (92lxsedan)
could be time for a fuel filter change, start with the little cheap things and work your way up
Old Jan 15, 2004 | 05:08 PM
turboxsi's Avatar
So what your trying to say is that everything DOESN'T run fine if your having this problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sivik2nr &raquo;</TD></TR><TR><TD CLASS="quote">one other thing to check is your TPS sensor. I had that same problem and it wasn't even throwing a code all the time.
But i would suggest looking at your tps sensor too and make sure its calibrated. I had the same problem with the car bogging a jerking really hard, and it turned out to be the tps sensor.
Good luck!!
Old Jan 15, 2004 | 05:12 PM
Hybrid CRX's Avatar
New User
yeah just cjed it, throwing codes 7 and 9
tps, and cylender sensor, maybe i should find this cylendor sensor, and run it directly to the ecu..
can anyone help? where is this cylinder sensor?
also what TPS would i use GSR? LS?
Old Jan 15, 2004 | 06:20 PM
scrap1ngsr's Avatar
Default Re: (Hybrid CRX)
I had a similar problems and I changed my spark plug wires and everything was fine
Old Jan 15, 2004 | 09:17 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (CivicSiR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiR94 &raquo;</TD></TR><TR><TD CLASS="quote">I had a similar problems and I changed my spark plug wires and everything was fine</TD></TR></TABLE>
THurr you go. I think that's more likely.
But before you actually go buying iridiums or something, pull your wires and plugs and check them for damange/corrosion/dirt/deposits, blaH. "Reading" your plugs gives you a good indication of whats going on in the motor.
Old Jan 15, 2004 | 11:01 PM
Hybrid CRX's Avatar
New User
how are the plugs supposed to look like, wires are new OEM wires.
Old Jan 16, 2004 | 08:51 AM
Hybrid CRX's Avatar
New User
ttt
Old Jan 16, 2004 | 07:35 PM
Hybrid CRX's Avatar
New User
ttt
Old Jan 17, 2004 | 01:19 AM
4inspeed's Avatar
not tryin to thread jack, but mine is doin the same thing exept, it smells REAL rich all the time. my vafc, doesnt show the throttle jumping around or any problem, no codes, cant figure it out. any idea's
***not tryin to thread jack***
ScandalousCivic
May 12, 2005 07:42 AM
ScandalousCivic
May 10, 2005 06:20 PM
tai93si
Jan 21, 2004 05:01 PM
TIRENECK
Jul 23, 2003 08:00 PM
b18bEG
Nov 7, 2002 06:49 PM
