I have $600 to spend...
Ok I have a B16 engine at a machineshop
I have $600 to spend for major parts (pistons/rods etc...)
I want to boost it(6-8psi)
what would be the cheapest route to go with good parts under $600
I assume you have a turbo setup already?
See if you can find some used forged pistons, and eagle rods. New stuff with bearings will cost more then $600...even used might cost more then that.
keep your stock rods (shotpeen them if its cheap with ARP rod bolts) find some used forged pistons.... new bearings (main and rod)..... i guess id use a block guard with how much money you are spending..... id almost be partial to sleeving that block and keeping everything stock
Blockguards aren't really worth it. There are plenty of people putting down serious power without a block guard.
The main weakness of honda engines is the stock cast pistons weak ringlands, and with D series engines, the small rods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan »</TD></TR><TR><TD CLASS="quote">The main weakness of honda engines is the stock cast pistons weak ringlands, and with D series engines, the small rods.</TD></TR></TABLE>
soooo true- thats what broke on my friends b16 turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1Z6 »</TD></TR><TR><TD CLASS="quote">things to buy with $600:
1. alarm
2. autolock
3. kill switch(s)
then any other mods.
alarms and autolocks dont do **** homie , i hope you dont find out the hard way.....kill switches do however work
1. alarm
2. autolock
3. kill switch(s)
</TD></TR></TABLE>alarms and autolocks dont do **** homie , i hope you dont find out the hard way.....kill switches do however work
1. alarm
2. autolock
3. kill switch(s)
naw dog
1. alarm
2. autolock
3. kill switch(s)
</TD></TR></TABLE>naw dog
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">
i guess we're left hopeless
</TD></TR></TABLE>i guess we're left hopeless
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav »</TD></TR><TR><TD CLASS="quote">Give the 600 to the support Trav fund! It's Tax Deductable and you can sleep better at night knowing you hepled people in need.
wtf? alarms and autolocks dont do ****?? I guess you had a bad experience, but My alarm and my autolock saved my car from being stolen numerous times. Sure thieves can bypass these things, but to amateurs they are not worth tampering with.
</TD></TR></TABLE>wtf? alarms and autolocks dont do ****?? I guess you had a bad experience, but My alarm and my autolock saved my car from being stolen numerous times. Sure thieves can bypass these things, but to amateurs they are not worth tampering with.
I have an itr crank for you if you want a 1.8L motor, e-mail me at JDMHondaEK_EG@yahoo.ca
92lxsleeper
Jan 22, 2011 11:44 AM
