AWFUL KNOCKING noise from engine
Old Jan 14, 2004 | 12:41 PM
civicboy95's Avatar
Default AWFUL KNOCKING noise from engine
Well to start with, I have a 95 civic ex coupe and just recently (4 days ago) my car has been making a werid sound(coming from the driver's side of the engine) . The sound can be best described as this: sounds like a fast woodpecker or a firing machine gun. So in other words, like a fast constant knocking. It doesnt really get louder or softer. It only happens when I am in motion and the car is shifted to neutral or in gear but not accelerating. When I am braking, completely stopped, or in gear and pressing the gas, it does not happen. I am 97% sure the sound is coming from the engine and not like the suspension or wheel because of the conditions the sound comes. Any ideas as to what this might be? Thanks alot!
Old Jan 14, 2004 | 02:19 PM
Blue Streak's Avatar
Default Re: AWFUL KNOCKING noise from engine (civicboy95)
i had a similar problem ended up spinning a rod bearing shortly afterwards. are you getting oil pressure? did you check your oil level?
Old Jan 14, 2004 | 02:26 PM
Spunkster's Avatar
When you hear things like this, for the love of god, stop driving he car, dont' turn it on and have it towed to a mechanic asap.
Old Jan 14, 2004 | 02:43 PM
Kendall's Avatar
Sounds like rod bearing problems to me. Start saving for a rebuild, or a new motor.
Old Jan 14, 2004 | 03:19 PM
vtekstorm's Avatar
Default Re: (Kendall)
how many miles on the motor??
Old Jan 14, 2004 | 03:32 PM
ChillOutWayne's Avatar
**** im getting a light knock at idle and crap too, i just did a rebuilt with OS forged CPs and eagle rods, it sounds like clearance with pistons to wall but who knows, to me yurs sounds worse and more like a rod bearing type of problem, not that id know but yea
Old Jan 14, 2004 | 03:40 PM
mmuller's Avatar
Mad Scientist
Default Re: (ChillOutWayne)
with engine running, disconnect one plug wire and connect it back, if its rod knock it will stop when you pull the plug for that cylinder.
Old Jan 14, 2004 | 05:58 PM
civicboy95's Avatar
Default Re: (mmuller)
the car has 102k miles. I had the timing belt and water pump replaced at 92k. Someone mentioned the CV joints? What exactly are these and could this be the problem?
Old Jan 14, 2004 | 06:07 PM
Green94GSR's Avatar
Default Re: (civicboy95)
If it happens when you are idling/not in motion it couldn't possibly be the CV joints. Those will usually start knocking when you go around a corner. Not knowing a hell of alot about clutch assemblies, could it possibly be a throwout bearing?
Old Jan 14, 2004 | 07:06 PM
senpai's Avatar
Default Re: (Green94GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green94GSR &raquo;</TD></TR><TR><TD CLASS="quote">If it happens when you are idling/not in motion it couldn't possibly be the CV joints. Those will usually start knocking when you go around a corner. Not knowing a hell of alot about clutch assemblies, could it possibly be a throwout bearing?</TD></TR></TABLE>
It could be the throwout bearing, but then the noise must go away once you press down on the clutch. My 90 SI does that right now; too cold to change out.
Old Jan 14, 2004 | 08:16 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: AWFUL KNOCKING noise from engine (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">When you hear things like this, for the love of god, stop driving he car, dont' turn it on and have it towed to a mechanic asap.</TD></TR></TABLE>
Especially since you apparently don't know much about engines.
TAKE IT TO A MECHANIC. DON'T DRIVE IT ANYMORE.
wv_treehanger
Nov 5, 2009 08:06 AM
battosai
Mar 29, 2008 11:32 AM
Toldge
Jun 23, 2005 03:28 PM
cromeo112
Aug 23, 2004 12:45 PM
civicboy95
17
Jan 14, 2004 05:58 PM
