Getting my motor redone need some suggestions
Old Jan 14, 2004 | 11:05 AM
2kflamedlude's Avatar
Default Getting my motor redone need some suggestions
Well I gonna go with jackson supercharger and Im thinking of getting the watter injection kit if I go 9lb pulley.. Any thought of this.. Also I might stroke my engine to 2.4 and go with 6lbs of boost any suggestions.. Whats the pros and cons?
Thanks.
Old Jan 14, 2004 | 11:13 AM
prelittlelude's Avatar
Default Re: Getting my motor redone need some suggestions (2kflamedlude)
how do you plan on stroking the motor. i like the idea of water injection , so old school. but what are you plans for compression ratio? are you sleving or what?
Old Jan 14, 2004 | 11:16 AM
Default Re: Getting my motor redone need some suggestions (prelittlelude)
Im already sleeved.. I have to get lower CR pistons.. I think it would be safer to run 9lb pulley and go with water injection.
Old Jan 14, 2004 | 11:34 AM
if your already sleved, then thats good. the price of going with a JRSC with water in jection vs a good turbo kit is pretty close. i mean in the long run its up to you. but i think 9:1 cr would be good.
agian how were you going to stroke it?
Old Jan 14, 2004 | 11:38 AM
I was hoping to find a stroker kit.. I hear some people stroked their H22a the shop who is doing my car has 744 hp H22a and man its crazy.. I rather go with supercharger honestly.. Any company make stroker kits?
Old Jan 14, 2004 | 12:14 PM
tell me why you want to go supercharged vs turbo? you will have to search around for a stroker kit. but then you will have a lower redline. if you are sleved you could always bore out more and acheive the larger displacement that way
Old Jan 14, 2004 | 12:20 PM
Well Im an SS lude.. My friend is rebuilding the tranny right now.. I got hold of a toque converter that is 800 rpm higher than stock.. Level 10 is few hundred RPM higher.. I just want the instant torque and boost.. Im not looking to be the fastest and also my car is daily driven.. 70 miles one way to work. So I am looking at the reliability issue here.. Hmm that sound like a good idea about boring it out more. But wont this cause overheating issues?
Old Jan 14, 2004 | 01:44 PM
SKDRCR's Avatar
Just remember, the more you bore it out,
the less room you have for error with your
block if you fry your pistons or anything.
Old Jan 14, 2004 | 02:12 PM
flip1199's Avatar
Default Re: Getting my motor redone need some suggestions (SKDRCR)
most companies say 89mm is max bore for a boosted h-series. What compression pistons do u have now? And what brand? What compression do u plan on going with? What's the highest octane gas u have available? Is there any way of cooling the air forced in the engine? If not it would be safer for turbo.
Old Jan 14, 2004 | 02:28 PM
Default Re: Getting my motor redone need some suggestions (flip1199)
Im runnin 11:5 cr JE and I going to go with 9.5 weisco and we can get any type of fuel up here over 100 octane.
iNERtIA
May 26, 2006 10:09 PM
Akura
May 16, 2005 06:50 PM
RuffGsR
Jun 23, 2004 06:43 AM
jdmcx
Oct 5, 2002 10:22 PM
proton
Jan 31, 2002 02:42 AM
