93 D tranny into 91
From: Commonwealth my ass This is the communist state, VA, USA
I know I have seen it on here before, But searching yields no results. My question is, Will it mount with no changes. Trans mount, Shift linkage, etc... I know I have three options as far as the clutch, 1. I can go with a "Home made" hydro to cable conversion... 2. I can go with a pre fab unit... 3. I can convert the car to hydro... Just need to know if the mounting points are the same and my 91 civic shift linkage will work... TIA
it can be doen. i don't know the exact things you need to do.. but i know the trany doesn't bolt in the car with stock mounts.. especialy since the 5th gen uses an L shaped rear motor mount bracket.. and the 4th gen doesn't. not to mention u loose the front mount then u gotta figured out what ur gonna do with the hydro converion.. which isn't easy by any means. all in all its not worth it.. go with a Si trans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 »</TD></TR><TR><TD CLASS="quote">it can be doen. i don't know the exact things you need to do.. but i know the trany doesn't bolt in the car with stock mounts.. especialy since the 5th gen uses an L shaped rear motor mount bracket.. and the 4th gen doesn't. not to mention u loose the front mount then u gotta figured out what ur gonna do with the hydro converion.. which isn't easy by any means. all in all its not worth it.. go with a Si trans</TD></TR></TABLE>
Ditto
Ditto
barrett_5
13
Oct 4, 2011 05:11 PM
tealsvteceg
Mar 10, 2008 07:15 PM
GetawayInMoscow
Jun 14, 2005 01:46 PM
