Screw extractor question
Old Jan 12, 2004 | 06:26 PM
JamesQ's Avatar
Default Screw extractor question
I recently put in Del Sol Seats into my 99 coupe. However, when I was first installing it, I was turning the socket wrench the wrong way and torqued it so much that the bolt head broke off. However, once i figured out i was turning the wrong way, I switched the seats just fine.
However, I still got to take care of this bolt, because only 3 of the 4 bolts holding the passenger side is in. I bought a screw extractor from home depot but didnt realized it didnt come with instructions. I know im suppose to drill the screw extractor into the broken bolt's center by a drill, but I'm unsure of what's next.
do I just turn the drill the other way and try to drill it out?
thanks guys
Old Jan 12, 2004 | 07:19 PM
dwnthehatch's Avatar
Default Re: Screw extractor question (JamesQ)
https://honda-tech.com/zerothread?id=567450
Old Jan 13, 2004 | 01:57 AM
JamesQ's Avatar
Default Re: Screw extractor question (dwnthehatch)
good instructions. I ended up not having to use the screw extractor because it wouldnt go in even though i drilled the hole. So i just use a small drill head to drill a small hole, then moved onto a bigger size so the drill head will attached to the drill. Then I just reversed the drill, and everything is groovy. Thanks though
Old Jan 13, 2004 | 11:00 AM
doublejz's Avatar
another way i found that works, is to get a welder and just keep building up the weld, then tack a nut on it. and unscrew it. You would have to get like canvas or something so it doesn't spider and burn your carpet
kevodean
Mar 31, 2009 01:24 PM
gsrmike
Apr 11, 2004 12:06 PM
JDMHN8
Jan 10, 2004 08:12 PM
92CxHatchback
Nov 4, 2003 07:01 AM
FastNFurious
May 17, 2003 12:54 AM
