CRV owners must read!!!!
My car been running like crap(misfire for 2 months.I changed fuel filter,wire set,dist.,plugs,rotor,cap,tried to changed the injectors but can't.To find out I have burnt valves(leak down test).I call the dealer thay said it's very common for CRV to have that problem IF YOU DON'T ADJUST YOUR VALVES EVERY 30 thou. miles.So,please learn from my mistake
....My car is fine now I put an Ls haed
Modified by indomotor at 9:51 PM 1/12/2004
....My car is fine now I put an Ls haedModified by indomotor at 9:51 PM 1/12/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by indomotor »</TD></TR><TR><TD CLASS="quote">My car been running like crap(misfire for 2 months.I changed fuel filter,wire set,dist.,plugs,rotor,cap,tried to changed the injectors but can't.To find out I have burnt valves(leak down test).I call the dealer thay said it's very common for CRV to have that problem IF YOU DON'T ADJUST YOUR VALVES EVERY 3 thou. miles.So,please learn from my mistake
....My car is fine now I put an Ls haed</TD></TR></TABLE>
Adjust the valves every 3,000 miles????
Did they mean 30,000?!
....My car is fine now I put an Ls haed</TD></TR></TABLE>Adjust the valves every 3,000 miles????
2000 cr-v se 69k miles. still going great. and, this car gets no maintenance done, except for oil change/tire rotation.
the first first gen ones i presume?
Mines has 80,xxx niles on it and it's still runnin good (knock on wood). Just normal oil changes since I bought the car at 30,xxx miles nothing else. I know.... It's needs some maintenence ASAP. But I have to say it's been taking a beating.
btw are your valves tapping really bad?
honda has a real interesting service bullitin out on this problem right now,but you have to know a honda tech to see it. I work in a dealer and seen the bullitin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bill-71SS »</TD></TR><TR><TD CLASS="quote">honda has a real interesting service bullitin out on this problem right now,but you have to know a honda tech to see it. I work in a dealer and seen the bullitin.</TD></TR></TABLE>
so why dont you be a nice guy and photocopy it or scan it to get it on here?
The bulletin he was speaking of is #03-038.
It covers CEL codes #P0301 & P0302 & P0303 & P0304 &/or P0172
This applies to ALL of the 1999 to 2001 CRV's
<FONT SIZE="3">Right click this image and "save as" to see it bigger</FONT> (not sure why it downsizes coming in here)
bump
I have an '07 CRV with 39,000 miles that just got the CEL p0303 code. No prior symptoms, but as soon as the CEL light up each time I started up the engine it sounded worse.
Took it to the dealership under the extended engine warranty and they proceeded to:
Change the spark plugs and coils, performed an injector balance test and a valve adjustment.
They found the valves were a little off, but nothing has fixed the problem, so they are getting in touch with Honda Technical Services to figure it out.
Any ideas??
Any ideas??
jdm_vtec
13
Jun 5, 2007 03:47 PM
haven't done it for over 50,xxx miles.
