location of greddy type-s BOV on charge piping....
Old Jan 11, 2004 | 04:51 PM
TRE_'s Avatar
Default location of greddy type-s BOV on charge piping....
i just got done installing my skunk2 intake manifold on my GSR motor(in my 98 civic), and everything went well except for the fact that the blow off valve sits way too high now(cant close the hood).. the throttle cable sits a little high now too but i think the hood should still be able to close.
so my question is, are there any designated areas on the charge piping that the BOV will be most efficient in? are there some areas/angles that are better or worse than others?
other then the hood closing problem, the car runs awesome, no CEL or anything like that and it pulls a lot harder/smoother in the mid-top range... one of the best mods to my car so far..
any help is appreciated, here is something i did in paint really quick(for the visual people)...
thanks in advance for any help
Old Jan 11, 2004 | 04:59 PM
igotyofire's Avatar
Default Re: location of greddy type-s BOV on charge piping.... (THE_HX)
well from my understanding the closer the BOV is to the compressor the better
Old Jan 11, 2004 | 05:01 PM
wanksta
Guest
Posts: n/a
um...i dunno. but maybe look at the thing thats connecting the bov to the charge pipe...looks pretty long. cut that down. 1 problem fixed and as for the throttle cable, get a shorter one! duh. i think an si or a sohc throttle cable will work.
Old Jan 11, 2004 | 05:04 PM
TRE_'s Avatar
Default Re: (wanksta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wanksta &raquo;</TD></TR><TR><TD CLASS="quote">um...i dunno. but maybe look at the thing thats connecting the bov to the charge pipe...looks pretty long. cut that down. 1 problem fixed and as for the throttle cable, get a shorter one! duh. i think an si or a sohc throttle cable will work.</TD></TR></TABLE>
yea i was thinking of just chopping that extenstion on the flange down.... hopefully that would give enough room...
Old Jan 11, 2004 | 06:04 PM
tegasaurus's Avatar
Default Re: (THE_HX)
if i was you, i'd just take a good 1.5 inches out of that crazy *** extention on the flange you have going on there.
Old Jan 11, 2004 | 06:37 PM
AmauryR's Avatar
For the throttle cable issue, you can have an oem look to it, grab a throttlebody from ur old sohc (or somebody's sohc), use the pulley on ur gsr tb, then go to the acura dealership and pick up a throttle cable and bracket from an itr, that way you have an oem look on ur skunk2 manifold.
PS. Instead of the sohc throttlebody, you can get an str one (if u wanna upgrade), they have holes on their pulley for gsr and non-gsr cables, dunno who else has that on their tb.
-l8r
Old Jan 11, 2004 | 06:57 PM
racerx7's Avatar
any where you can make it fit will work
Old Jan 11, 2004 | 07:04 PM
mrod006's Avatar
Default Re: (racerx7)
yup, u might need to cut the flange a little. i had to do the same with my civic and hood clearance is fine.
Old Jan 11, 2004 | 07:17 PM
TRE_'s Avatar
Default Re: (Death Scythe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Death Scythe &raquo;</TD></TR><TR><TD CLASS="quote">For the throttle cable issue, you can have an oem look to it, grab a throttlebody from ur old sohc (or somebody's sohc), use the pulley on ur gsr tb, then go to the acura dealership and pick up a throttle cable and bracket from an itr, that way you have an oem look on ur skunk2 manifold.
-l8r</TD></TR></TABLE>
thanks a bunch for the info man... i really appreciate it...
i'll most likely just cut the flange down like i had orginally planned to do, but i figured if that wouldnt work i'd find out where another good spot would be to put the BOV... thanks for all the info guys..
Old Jan 12, 2004 | 07:21 PM
typeR#0427's Avatar
where are the rest of the pics? I hope that everything is working good
Old Jan 12, 2004 | 07:27 PM
TRE_'s Avatar
Default Re: (hamB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">where are the rest of the pics? I hope that everything is working good </TD></TR></TABLE>
i havent had a chance to upload them yet... but yea everything is running great excpet for that annoying vacuum sound coming from that little black "thing"..
Old Jan 15, 2004 | 12:35 AM
forcedairtech.com's Avatar
that good tre u love the new manifold .
Old Jan 15, 2004 | 06:07 AM
kpt4321's Avatar
You want the BOV towards the throttle body, because the air mass as inertia in that direction.
If you can just cut the flange shorter, you'll be fine. Worse case, move it down some, which is also fine.
Old Jan 15, 2004 | 08:59 AM
TRE_'s Avatar
for anyone that cares, heres what i ended up doing:
clearance is great now.
Old Jan 15, 2004 | 09:12 AM
m.'s Avatar
m.
kinda OT but are you running nitrous??
Old Jan 16, 2004 | 07:03 PM
TRE_'s Avatar
Default Re: (10SPDHuffy)
no.... the SS braided line that you see is tee'd off the fuel line to a fuel pressure gauge...
Old Jan 17, 2004 | 12:32 PM
typeR#0427's Avatar
Looks good Tre!
Old Feb 2, 2004 | 12:09 PM
RudeLude's Avatar
what kinda mani is that? looks nice
daniel
Old Feb 2, 2004 | 07:29 PM
typeR#0427's Avatar
Default Re: location of greddy type-s BOV on charge piping.... (RudeLude)
Skunk2,
Old Feb 3, 2004 | 06:52 AM
RudeLude's Avatar
Default Re: location of greddy type-s BOV on charge piping.... (hamB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2, </TD></TR></TABLE>
i meant exh mani, haha sorry
daniel
Old Feb 3, 2004 | 08:53 AM
TRE_'s Avatar
its a max-rev manifold.
Old Feb 3, 2004 | 09:23 AM
jmagner's Avatar
Shoulda extended that flange instead and cut a hole in ur hood
btw, nice job on the flange + nice setup
Old Feb 3, 2004 | 09:30 AM
TRE_'s Avatar
Default Re: location of greddy type-s BOV on charge piping.... (jmagner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmagner &raquo;</TD></TR><TR><TD CLASS="quote">btw, nice job on the flange + nice setup</TD></TR></TABLE>
thanks!
MilanoRed_EJ8
Jan 25, 2009 06:44 PM
97spooncivic
Mar 26, 2006 06:04 PM
95EXcivicsleeper
Apr 22, 2004 01:39 PM
Cramerox
Apr 13, 2002 06:09 PM
Chip398193
Oct 2, 2001 12:22 PM
