location of greddy type-s BOV on charge piping....
i just got done installing my skunk2 intake manifold on my GSR motor(in my 98 civic), and everything went well except for the fact that the blow off valve sits way too high now(cant close the hood).. the throttle cable sits a little high now too but i think the hood should still be able to close.
so my question is, are there any designated areas on the charge piping that the BOV will be most efficient in? are there some areas/angles that are better or worse than others?
other then the hood closing problem, the car runs awesome, no CEL or anything like that and it pulls a lot harder/smoother in the mid-top range... one of the best mods to my car so far..
any help is appreciated, here is something i did in paint really quick(for the visual people)...
thanks in advance for any help
Re: (wanksta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wanksta »</TD></TR><TR><TD CLASS="quote">um...i dunno. but maybe look at the thing thats connecting the bov to the charge pipe...looks pretty long. cut that down. 1 problem fixed and as for the throttle cable, get a shorter one! duh. i think an si or a sohc throttle cable will work.</TD></TR></TABLE>
yea i was thinking of just chopping that extenstion on the flange down.... hopefully that would give enough room...
Re: (THE_HX)
For the throttle cable issue, you can have an oem look to it, grab a throttlebody from ur old sohc (or somebody's sohc), use the pulley on ur gsr tb, then go to the acura dealership and pick up a throttle cable and bracket from an itr, that way you have an oem look on ur skunk2 manifold.
PS. Instead of the sohc throttlebody, you can get an str one (if u wanna upgrade), they have holes on their pulley for gsr and non-gsr cables, dunno who else has that on their tb.
-l8r
-l8r
Re: (Death Scythe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Death Scythe »</TD></TR><TR><TD CLASS="quote">For the throttle cable issue, you can have an oem look to it, grab a throttlebody from ur old sohc (or somebody's sohc), use the pulley on ur gsr tb, then go to the acura dealership and pick up a throttle cable and bracket from an itr, that way you have an oem look on ur skunk2 manifold.
-l8r</TD></TR></TABLE>
thanks a bunch for the info man... i really appreciate it...
i'll most likely just cut the flange down like i had orginally planned to do, but i figured if that wouldnt work i'd find out where another good spot would be to put the BOV... thanks for all the info guys..
Re: (hamB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamB18C1 »</TD></TR><TR><TD CLASS="quote">where are the rest of the pics? I hope that everything is working good </TD></TR></TABLE>
i havent had a chance to upload them yet... but yea everything is running great excpet for that annoying vacuum sound coming from that little black "thing"..
You want the BOV towards the throttle body, because the air mass as inertia in that direction.
If you can just cut the flange shorter, you'll be fine. Worse case, move it down some, which is also fine.
Re: location of greddy type-s BOV on charge piping.... (hamB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamB18C1 »</TD></TR><TR><TD CLASS="quote">Skunk2, </TD></TR></TABLE>
i meant exh mani, haha sorry
daniel
daniel
Re: location of greddy type-s BOV on charge piping.... (jmagner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmagner »</TD></TR><TR><TD CLASS="quote">btw, nice job on the flange + nice setup</TD></TR></TABLE>
thanks!
thanks!
MilanoRed_EJ8
01-25-2009 06:44 PM
