ECU Code 9 CYP Sensor
Old Jan 11, 2004 | 12:15 PM
incognitoracerr's Avatar
Default ECU Code 9 CYP Sensor
I did my tune-up today and as I was changing the rotor and cap I noticed the CYP Sensor was dirty. So I unscrewed it and cleaned it off. Now I put everything back together and I have the CYP Sensor light coming on through my check engine light (code 9). The car runs a lot better since I changed everything but now I have that check engine light...any suggestions on what I could have done wrong?....do you think cleaning it made the ecu realize it's faulty?...is it something I have to fix before I can drive again?
Old Jan 11, 2004 | 05:15 PM
Default Re: ECU Code 9 CYP Sensor (incognitoracerr)
bump for night help
Old Jan 11, 2004 | 05:22 PM
Sliced Beard's Avatar
try resetting the ecu and see fi the cel comes back
Old Jan 11, 2004 | 05:26 PM
Default Re: ECU Code 9 CYP Sensor (dirtyd463)
i tried that but it comes back on
Old Jan 11, 2004 | 05:29 PM
well try and replace the sensor and see what that does
Old Jan 11, 2004 | 05:31 PM
the thing is that to replace the sensor i have to get a new distributor because they don't sell the sensor alone or separate...which sucks...so i know i have to buy one regardless...i just kinda want to know if it will be ok to drive the car like that until i can get one...thanks for the help though
Old Jan 11, 2004 | 06:09 PM
what kinda engine do you have
Old Jan 11, 2004 | 06:12 PM
D15 vx
Old Jan 11, 2004 | 06:20 PM
Altered's Avatar
Find another distributor and swap the internals out for that of a working distributor. I swapped the guts from a 90 DX distributtor into a 89 OBD0 B16 distributor and later on that same day did the same thing with another OBD0 B16 distributor, the second time I took the guts from a 91 LS dizzy. Both worked perfect and are still running fine over a year later.
Old Jan 11, 2004 | 06:24 PM
Default Re: ECU Code 9 CYP Sensor (Altered)
hey guys i don't mean to sound like an *** but I know what I need to do to fix the problem...my question is can i drive the car like this for a few days until i can find another dizzy?....thanks for the idea's though...
Old Jan 11, 2004 | 06:59 PM
hondatim's Avatar
Yes, the car can be driven.
Old Jan 11, 2004 | 07:13 PM
Default Re: ECU Code 9 CYP Sensor (hondatim)
thanks...thats all i wanted to know...what is the downfall though?..i mean since it could be driven what is the bad part about driving it like that?
roy ezechukwu
Feb 6, 2014 02:13 PM
Milby90ls
Sep 10, 2011 09:13 AM
CivicHB91
Jan 22, 2003 03:31 PM
