Fuel relay&pump quick question
Old Jan 11, 2004 | 12:30 AM
jakester's Avatar
Default Fuel relay&pump quick question
Car not starting. Not hearing fuel pump priming any more. Check the relay? Is it in inside fuse box? Fuel level wasn't registering properly shortly before no start problem. Fuel pump toast? Had problems starting intermittantly,before now.
Old Jan 11, 2004 | 10:27 AM
typertn's Avatar
Default Re: Fuel relay&pump quick question (jakester)
what year accord is it?
Old Jan 12, 2004 | 12:05 AM
Kelly.'s Avatar
I've quit using this account
on the 5th gen accords, the wires that powers the fuel pupm is black w/ yellow stripe and silver dots on it.
get a muiltmeter and with the key on see if you are getting voltage back there.
its a start
Old Jan 12, 2004 | 12:19 AM
jakester's Avatar
Default Re: (llewsirc)
Got it! The problem was with the sending unit ground connection. Over the years it has just worked itself loose. I have owned this car for over ten years and haven't ever touched it. I wasn't even aware the ground was behind the rear seat (now I know!). Car is a 91 EX. I was also surprised to see what a crappy ground connection this is.
nichole82
Mar 28, 2012 08:30 AM
ef9itb
Jan 19, 2010 10:48 AM
JDM illmatic
11
Jul 25, 2008 04:41 PM
incognito E46
Feb 21, 2006 05:33 PM
