problem after nitrous install (VCN-2000)
My friend Chad up at RandD had the kit on his car for a couple of days and it would throw a TPS code when it was spraying. He took it off cause he got pissed off at it. So I installed it in my car today. Went out to test it out and again with the tps code. It displays TPS ERROR on the display and I get a CEL 7 and the engine jerks kinda bad when the cel comes on. Anyone know what the problem could be? Its a Venom VCN-2000 kit. Thanks for the help.
Modified by EF9_SiR at 4:42 AM 1/11/2004
JESUS F-IN CHRIST. It is the VENOM VCN-2000 kit. IT IS A DAMN DRY KIT. IT GOES INTO THE INTAKE. If you don't know what kind of system this is then you wont be able to help. PERIOD!
wow nice attitude! where on the intake chr pipe is the jet installed? is it before or after the air intake temp sensor? if youre spraying n20 before the sensor, its causing the temp to drasitically decrease.
the reason I am acting the way I am is because if you don't know the system you wont be able to help. This kit IS NOT your typical nitrous kit.
It is installed in the intake arm. I have a 92 so the temp sensor is in the intake mani.
did you try venoms website? http://www.venom-performance.c...2.pdf this might help. Please dont yell at me if it doesnt
Yeah that is a bad unit i had the same kit and i had other problems with mine not just the error that you got. i had my installed by a shop too. The swaped out the unit and it worked fine. i had them rip that **** out and went with zex now thats a fine *** kit.
Dancing is Forbidden
Sep 10, 2014 11:16 AM
