a few questions to finish up swap...
Old Jan 10, 2004 | 05:09 PM
Combustion Contraption's Avatar
Default a few questions to finish up swap...
im 95% done, and just have a few questions....
where do these hoses go? (circled for ease of viewing )
this connector is coming from the underside of the tranny and i cannott find a spot to plug it in... am i just blind? its a y21 tranny from a del sol VTEC into a 92 vx hatch if it matters...TIA!
Old Jan 10, 2004 | 05:16 PM
Turbogixxer's Avatar
Default Re: a few questions to finish up swap... (LsVtec92Hatch)
#1 it is a coolant nipple that goes to your fast idle on the TB
#2 it is hard to tell, can you take a pic not so close to it.
#3 not sure, not so close, so I can see the rest of the motor.
#4 looks like the reverse light connector, but not sure.
Old Jan 10, 2004 | 05:54 PM
i cant take any more pics right now so i hope this helps....
#2 - its right below and to the right ofq where the battery would sit and the hose just comes out of the firewall....
#3 - the big hose under the fitting in the pic is the upper radiator hose if that gives you any idea....
Old Jan 10, 2004 | 06:31 PM
Default Re: (LsVtec92Hatch)
#2 sounds like the a/c drown
Old Jan 10, 2004 | 06:37 PM
B20vtec86crx's Avatar
#2 evap canister drain
#3 i think ...to fast idle other end from fast idle to aic valve other end of aic valve to #1...not 100% sure on #3
demon del sol
13
Apr 23, 2012 08:32 AM
wilson091
Mar 18, 2012 01:22 PM
jinxd12
Sep 6, 2010 01:11 PM
osaltyone
Oct 3, 2006 11:01 AM
90civichb
32
Jun 24, 2004 02:39 PM
