Nasty Rattle...need some help
Old Jan 10, 2004 | 04:31 PM
UnionCity LS's Avatar
Default Nasty Rattle...need some help
Alright, i got a 99 LS...Dc header, Greddy cat back...and when im driving for the first 5 min or so...before the pipes warm up and start to expand its cool. But after that when it is warm i hear this nasty rattle as im coming to a stop and accelorating. So i was thinking my heat shield above my Cat is against the piping so i take it off, go for a drive and its still rattling, and it sounds like its comming from the back where the passanger seats are. and i looked underneath and i still couldnt really tell what was making the noise.
Any suggestions?
TIA
oh yeah....should i put my heat shield back on? cause it was a bitch to take off?
Old Jan 10, 2004 | 04:51 PM
redGSRguy's Avatar
Default Re: Nasty Rattle...need some help (UnionCity LS)
Mine rattled like crazy where the cat was touching the front swaybar.
Old Jan 10, 2004 | 05:32 PM
Default Re: Nasty Rattle...need some help (redGSRguy)
intresting...ill look into that, but for me, the rattle is more towards the rear...anyone else..thanks redGSRguy..
Old Jan 10, 2004 | 06:41 PM
SIanara's Avatar
i wuold say jack up the car securely and start it up. get under there with your ears and scope it out.i've had a rattling problem in a previous car i owned , ,but i thought it was somethign in the cat....check it out
Old Jan 10, 2004 | 06:51 PM
Default Re: (vteGraGSR)
yeah thats what i was doing all day... sucks not having a lift, but i did use a jack and some jack stands, looked around, tapped on a few things tightened some bolts..and bam, still have the rattle... thanks tho
Old Jan 10, 2004 | 07:00 PM
13secVTEC
Guest
Posts: n/a
Default Re: (UnionCity LS)
i actually have a rattle in the mesh inside of my muffler (apex n1) so i have a rattle from 3000-3600 rpm its annoying as hell. u might wanna check that. just my advise..
does anyone know how to fix a internal rattle like mine?
Old Jan 10, 2004 | 07:59 PM
Default Re: (13secVTEC)
sounds like somthin i might have.... i think imma just take it to the shop, it almost sounds as if its coming from the resinator? because all of the heat shields from the cat back are tight and not loose, so i doubt thats the rattling.
Old Jan 11, 2004 | 12:18 AM
Kryptonite's Avatar
maybe the cat-back is a little loose?
when i had this weird noise i check my cat-back & there was a loose nut
Old Jan 11, 2004 | 10:30 AM
IVI's Avatar
IVI
Default Re:
check the exhaust hangers also. theyre known to do that.
you may want ot get new stiffer hangers , theyre a couple of dollars each.
itll stop your exhaust from rattling. or hitting the under-carriage of the car.
Old Jan 11, 2004 | 04:56 PM
hondamanwill's Avatar
Had mine break the bracket on top of muffler to over axle pipe.
Old Jan 11, 2004 | 06:29 PM
DiRT!'s Avatar
BLAH
Old Jan 11, 2004 | 07:02 PM
Brian_TII's Avatar
Also make SURE that it's not the cat making the noise... cats can cause rattles like mad when they are falling apart. (I know from PLENTY of experience here...) Sometimes it's hard to tell exactly where the sound is coming from so you may want to just make sure it's not the cat.
Old Jan 11, 2004 | 08:08 PM
TeGGY_LS's Avatar
Default Re: (Brian_TII)
i had the same rattle..........took off all my heat shields after my cat........no more rattling for my car. took them off during my exhaust install.....by the way jus installed greddy sp2 on my integra....love the exhaust gives a moaning sound and only orgasms wen u punch it!
Old Jan 11, 2004 | 09:54 PM
mEr's Avatar
mEr
try your exhasut canal, mine was touching the side and made a nasty rattling, i just bent it out of the way and bang.........problem solved!!
Old Jan 11, 2004 | 09:57 PM
jdmintegra1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian_TII &raquo;</TD></TR><TR><TD CLASS="quote">Also make SURE that it's not the cat making the noise... cats can cause rattles like mad when they are falling apart. (I know from PLENTY of experience here...) Sometimes it's hard to tell exactly where the sound is coming from so you may want to just make sure it's not the cat.</TD></TR></TABLE>
^^^My guess. You have either an internally blown catalytic converter, or your exhaust hangers are hitting something.
Old Jan 12, 2004 | 07:42 AM
Sweetsystem's Avatar
I heard those types of Problems are warrented by the manufactuere for up to one year and some times 5. Check with them or give them hell about it and they should replace it.
Refering to the Apex N1 internal rattle problems.
Mine also has that problem but its a generic cheap loud exahust that sound like rocks in a tin can.
Old Jan 12, 2004 | 12:14 PM
DA-nteg's Avatar
Default Re: (Sweetsystem)
i know exactly what your talking about... on the rear of my g2 it did the same.. after much headache.. i went and bought new hangers and it raised the xhaust up a tad.. and it stopped... my guess was it was rubbing on the chasis where the b-pipe and rear section connect over the rear arms.
Old Jan 12, 2004 | 12:21 PM
DA-MAX's Avatar
Default Re: (DA-nteg)
same prob here on my DA..I plan to get new hangers next week. rattling only started when it got cold though...I guess the weather fucked with the rubber hangers somehow.
Old Jan 12, 2004 | 02:45 PM
BIGGIDYBOB's Avatar
Default Re: (DA-MAX)
i had a rattling problem when i had my greddy sp. Found out that the resonator was going bad so i had to weld a pipe in place of it. Rattling problem was fixed! So check on that and also if your axle back portion is hitting the rear sway
jugodmyko
13
Sep 21, 2007 05:23 AM
89efDUSTY
Mar 9, 2007 08:48 AM
lastpunkinline
Apr 7, 2005 07:48 AM
mickey513
Jun 25, 2003 12:26 PM
StinkyTofu
Feb 16, 2003 12:27 AM
