***Where'd you mount your ignition setup?***
I am installing my crane cams ignition, and i found a decent spot for my control box, but having a hard time with the coil pack.. whered you mount yours? pictures are a
TIA
Nick
TIA
Nick
i mounted mine under my cai. i fabricated a plate with a bracket and mounted it between the abs unit and the reservoir of my antifreeze. both pieces fit and it came out smooth. good luck.
my ignition box is in the glovebox, coil is mounted on the shock tower
i used to have my old ignition mounted behind the center console under the dash kinda... if you take a peek back there it's a really nice little spot that many people neglect to notice. then again, i have a lot of stuff stripped out of my car such as srs, and i THINK that some SRS stuff was there... still plenty of room though....
-Erik
-Erik
