*** Urgent: Help with Progress rear swaybar install ***
Old Jan 9, 2004 | 06:14 PM
p0pe's Avatar
Default *** Urgent: Help with Progress rear swaybar install ***
Ok... me and a couple of friends are installing my progress rear swaybar and it's supposed to require drilling into the subframe. Once you drill the holes how do access the top of the subframe crossbeam to drop the bolts down?
Modified by p0pe at 10:30 PM 1/9/2004
Old Jan 9, 2004 | 06:31 PM
Nick H's Avatar
New User
Default Re: *** Urgent: Help with Progress rear swaybar install *** (p0pe)
are you sure that you weren't supposed to drill into the rear trailing arm instead...i don't know about the progress bar, but the suspension techniques bar only requires drilling into the rear trailing arms about 1 inch in front of the factory sway bar location...
Old Jan 9, 2004 | 06:34 PM
p0pe's Avatar
Default Re: *** Urgent: Help with Progress rear swaybar install *** (Nick H)
No.. we already have the swaybar mounted to the trailing arm. The drilling that's required for the progress install is into the center crossbeam of the subframe. It bolts a 'D' bracket around the swaybar and holds it to the subframe.
------ <----subframe crossbeam
\(..)/ <----- 'D' bracket around swaybar
Old Jan 9, 2004 | 06:38 PM
Nick H's Avatar
New User
oh i see...well i'd guess it would be either right behind the seat or under it maybe...you are going to have to start looking around and take out the back seat most likely...sorry i can't help too much...my suspension techniques bar mounted to the factory sway bar mounts in the center crossbeam...
Old Jan 9, 2004 | 07:44 PM
p0pe's Avatar
updated with new pics... anyone know if I have to unbolt the lca's, drop the crossbeam, then drill into it once it's off the car?
Old Jan 9, 2004 | 07:49 PM
spankey167's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p0pe &raquo;</TD></TR><TR><TD CLASS="quote">No.. we already have the swaybar mounted to the trailing arm. The drilling that's required for the progress install is into the center crossbeam of the subframe. It bolts a 'D' bracket around the swaybar and holds it to the subframe.
------ &lt;----subframe crossbeam
\(..)/ &lt;----- 'D' bracket around swaybar</TD></TR></TABLE>
Did your progress rear sway come with mounting brackets? I have ST front and rears. And my rear came with mounting brackets. They are the ones in black right above the red bushings. Heres a pic
Old Jan 9, 2004 | 07:59 PM
p0pe's Avatar
Default Re: *** Urgent: Help with Progress rear swaybar install *** (spankey167)
Yeah the came with mounting brackets (the 'D' brackets) but the brackets must be mounted into the rear subframe. My question is, how do I access the top of the subframe? Do I have to unbolt the control arms from it and drop it before drilling?
Old Jan 9, 2004 | 10:08 PM
Nick H's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p0pe &raquo;</TD></TR><TR><TD CLASS="quote"> Do I have to unbolt the control arms from it and drop it before drilling?</TD></TR></TABLE>
that's the only way that i can see you will be able to do it...
Old Jan 9, 2004 | 11:11 PM
spankey167's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p0pe &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the came with mounting brackets (the 'D' brackets) but the brackets must be mounted into the rear subframe. My question is, how do I access the top of the subframe? Do I have to unbolt the control arms from it and drop it before drilling?</TD></TR></TABLE>
I dont know what your talking about drilling into the subframe... I've heard civics and integras do it but for our accords you dont need to. For mine i just unbolted a bolt underneath the rear crossmember, put the bracket on ( the bracket should have an opening in the middle of it for the bolt to go through) and bolt it on.
Old Jan 10, 2004 | 05:36 AM
p0pe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankey167 &raquo;</TD></TR><TR><TD CLASS="quote">
I dont know what your talking about drilling into the subframe... I've heard civics and integras do it but for our accords you dont need to. For mine i just unbolted a bolt underneath the rear crossmember, put the bracket on ( the bracket should have an opening in the middle of it for the bolt to go through) and bolt it on. </TD></TR></TABLE>
You must be talking about the ST swaybar. The progress mounting bracket comes with 3 holes in it and specifically says you need to drill 4 holes and use 2 existing ones.
Old Jan 10, 2004 | 08:05 AM
HAccord96's Avatar
You must be talking about the ST swaybar. The progress mounting bracket comes with 3 holes in it and specifically says you need to drill 4 holes and use 2 existing ones.</TD></TR></TABLE>
That sucks. I guess the ST sway is alot easier to install. Took a friend and me 10 minutes to install...
Old Jan 10, 2004 | 10:17 AM
azian21485's Avatar
sorry i can't help..but please keep us updated on how the car handles after installation...did you have the s/t rear before the progress one? I'm thinking about getting progesss swaybar too because its 2mm larger than s/t but i get second thoughts when it comes to drilling
Old Jan 10, 2004 | 12:05 PM
spankey167's Avatar
Yes i do. I never knew you had to do so much for the progress sway... My ST one was very easy to install. No drilling requireed at all...
Old Jan 10, 2004 | 12:23 PM
p0pe's Avatar
Default Re: *** Urgent: Help with Progress rear swaybar install *** (azian21485)
Just finished installing... supposed to drill 4 holes but we couldn't figure out where to drill 2 of em. We ended up using 2 existing bolts under the car for the other 2 mounting points. Kinda ghetto but the instructions made no sense and didn't elaborate on where exactly the mounting points were supposed to be. Drilling into the subframe is a _pain in the ass_.
Old Jan 10, 2004 | 04:27 PM
fluxion's Avatar
amin n'rangwa edanea
sometimes you just gotta improvise. looks good to me though, how's the ride?
Old Jan 10, 2004 | 04:34 PM
p0pe's Avatar
Default Re: *** Urgent: Help with Progress rear swaybar install *** (fluxion)
The ride is excellent... the rear end feels solid and doesn't roll much at all. I'll post again after my first autox event tommorow...
Old Jan 11, 2004 | 12:01 AM
azian21485's Avatar
the pics are down...and will your method work just as well as drilling into the subframe?
btw where did you purchase the bar from and how much did it cost?
Modified by azian21485 at 9:16 AM 1/11/2004
Old Jan 13, 2004 | 05:37 AM
p0pe's Avatar
I attended my first autox Sunday and the progress bar felt great, especially in the slaloms & hairpins. A friend watching said the car didn't roll much at all and looked very stable. When I would push the car hard the rear end felt like it wanted to kick out and I had to save it a couple of times. I didn't hit a cone the entire event and ended up placing 5th out of around 10 cars in STS, around 1 or 2 seconds behind the 1st place car I think. I would definately recommend this swaybar to anyone, especially for autox.
edit: Also, I looked at the mounts after the event and they held up fine, but I may get my bro. to tack weld they mounts to the subframe just to be safe.
Modified by p0pe at 8:49 AM 1/13/2004
Old Jan 13, 2004 | 05:47 AM
p0pe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 &raquo;</TD></TR><TR><TD CLASS="quote">the pics are down...and will your method work just as well as drilling into the subframe?
Modified by azian21485 at 9:16 AM 1/11/2004</TD></TR></TABLE>
I got mine for around $200-215 a year ago from lightningmotorsports.com. I searched and found this : http://www.genxmuscle.com/store/62-1011, they have them for $171.
Old Jan 13, 2004 | 12:36 PM
accordfreak's Avatar
thanks for the write up!
anybody up for a groupbuy? mr mike's brother can hook us up for cheaper i believe
check out his install https://honda-tech.com/zerothread?id=666415
Modified by accordfreak at 2:12 PM 1/13/2004
chriskory
10
Apr 26, 2014 05:13 PM
ian1006
Honda CR-V & Element
Jan 25, 2014 03:41 PM
auto addict
Jul 6, 2008 12:47 PM
Hairy Hudson
May 14, 2008 07:24 PM
cu_jarrett
May 6, 2004 08:25 PM
