check light on?
Old Jan 9, 2004 | 04:48 PM
aandDavidsaid's Avatar
Default check light on?
i just install a new intake in my 2000 si and my light came on. so how do i get it to shut off. thanks for any help.
Old Jan 9, 2004 | 04:55 PM
Jimmy's Avatar
Global Moderator
Default Re: check light on? (jdmrac3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrac3r &raquo;</TD></TR><TR><TD CLASS="quote">i just install a new intake in my 2000 si and my light came on. so how do i get it to shut off. thanks for any help.</TD></TR></TABLE>
reset your ecu...pull the ecu fuse or take the neg battery cable off for 5 mins...goodluck
Old Jan 9, 2004 | 04:56 PM
upgraded's Avatar
make sure you didn't unplug your air intake temp sensor or your map sensor, if you did, plug them back in.
Old Jan 9, 2004 | 05:00 PM
Default Re: (upgraded)
i think is did pull the sensor but there wasn't a plug on the intake so its just hang there what do i do.
Old Jan 9, 2004 | 05:17 PM
Formula 1's Avatar
Default Re: (jdmrac3r)
you prolly bought the wrong intake...or if u got the right one u need to pull the connector and probe from your other in take its a lil black thing that plugs into the intake...then u connect the iat to that and u shoudl be set ....hope this helps
Old Jan 9, 2004 | 05:19 PM
Default Re: (SikCivic)
if i leave it with the check light will it mess up my engine
Old Jan 13, 2004 | 09:37 AM
Formula 1's Avatar
over a period of time it could or it can go faster. basically cel is on something wrong is happening. just reset it and make sure the plugs r in right u should be fine
post up some pics if u having trouble
Old Jan 13, 2004 | 09:50 AM
Grimm's Avatar
FYI: to reset the ECU by removing the neg- from the battery will also clear all pre-sets and times on everything in your car. An easier way is to just unplug the ECU.
Remove the passenger side kick plate, then just unplug the 3 connectors. Your radio will maintain it's correct time and your radio presets will remain intact...
Old Jan 15, 2004 | 12:50 AM
Formula 1's Avatar
Default Re: (Grimm)
u can also do that...i dont care bout resetting the times and crap i always have cds in so no stations and my cd player auto sets the eq wit a button
RA062224
Honda Civic (2001 - 2005)
Jul 5, 2007 12:34 PM
hondachick05
Aug 19, 2005 10:40 PM
StraightCivic
Jul 1, 2005 01:53 AM
sik26
Mar 19, 2005 08:02 PM
