check light on?
Global Moderator
Re: check light on? (jdmrac3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrac3r »</TD></TR><TR><TD CLASS="quote">i just install a new intake in my 2000 si and my light came on. so how do i get it to shut off. thanks for any help.</TD></TR></TABLE>
reset your ecu...pull the ecu fuse or take the neg battery cable off for 5 mins...goodluck
Re: (jdmrac3r)
you prolly bought the wrong intake...or if u got the right one u need to pull the connector and probe from your other in take its a lil black thing that plugs into the intake...then u connect the iat to that and u shoudl be set ....hope this helps
Re: (jdmrac3r)
over a period of time it could or it can go faster. basically cel is on something wrong is happening. just reset it and make sure the plugs r in right u should be fine
post up some pics if u having trouble
Re: (SikCivic)
FYI: to reset the ECU by removing the neg- from the battery will also clear all pre-sets and times on everything in your car. An easier way is to just unplug the ECU.
Remove the passenger side kick plate, then just unplug the 3 connectors. Your radio will maintain it's correct time and your radio presets will remain intact...
Re: (Grimm)
u can also do that...i dont care bout resetting the times and crap i always have cds in so no stations and my cd player auto sets the eq wit a button
Check engine light after installing intake, searched forever and havent found any anwsers please hel
hondachick05
08-19-2005 10:40 PM
StraightCivic
07-01-2005 01:53 AM
cereeb4
02-21-2004 10:45 AM
