STR Throttlebody/Skunk2 manifold Problem
Old Jan 9, 2004 | 04:00 PM
quickda6's Avatar
Default STR Throttlebody/Skunk2 manifold Problem
I have a S2 mani and 68mm str t-body, and my idle wont drop below 1500 when warm. It is a vacum leak at the t-body gasket, specifically the top corner towards firewall. STR says the s2 mani's are made in taiwan and arent perfectly flat. I have tried rtv on that area, and still get the leak.
Anyone else ever hear of this or have the same problem? Should i go as far as taking the manifold to a machine shop to make it level or maybe double up on the gasket? I havent spoke to skunk2 on the matter yet, but str makes it sound like it happens all the time. TIA
Old Jan 9, 2004 | 06:59 PM
quickda6's Avatar
Default Re: STR Throttlebody/Skunk2 manifold Problem (quickda6)
guess im the only one with this problem
Old Jan 9, 2004 | 07:11 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
have u tried a different throttle body?..or do u know for sure its the manifold?
Old Jan 9, 2004 | 08:02 PM
b16powwer's Avatar
i had the same problem for years, if you have a vafc, you can fix this problem. go to the narrow in the settings, and drop it down to -20. i willl try to get a pic and show you what i mean.
Old Jan 9, 2004 | 08:42 PM
quickda6's Avatar
Default Re: STR Throttlebody/Skunk2 manifold Problem (b16powwer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy &raquo;</TD></TR><TR><TD CLASS="quote">have u tried a different throttle body?..or do u know for sure its the manifold?</TD></TR></TABLE>
no, but thats a good way to be 100%, good call bruce
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16powwer &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem for years, if you have a vafc, you can fix this problem. go to the narrow in the settings, and drop it down to -20. i willl try to get a pic and show you what i mean.</TD></TR></TABLE>
so you lean it out a little?
Old Jan 16, 2004 | 05:39 AM
FULL-RACE EP3's Avatar
stick your little thumbc@ck in there, that oughta do the trick
marble hatch
Oct 16, 2006 07:07 AM
THEO-Vtec
Jan 21, 2005 06:57 PM
Merilious
Jun 22, 2004 10:46 AM
SuperCivic
18
Oct 4, 2002 11:11 AM
BoostedGSRBubble
13
Jun 7, 2002 12:31 PM
