cam gear bolt backed out?
well yesterday while going home my intake gear bolt back up and shreaded the front of the camshaft. can i use the stock intake cam shaft with the crower 402T exhaust cam. or do i have to use both stock cams? this is for a LS.
i dont understand - you damaged your cam so bad it is unusable?
if so I would swap both stockers back in unless you want to investigate and compare the mixing of the cams for a few days?
OrangeBoost
13
Apr 25, 2006 06:50 PM
