cam gear ques.
if you have stock cams there is a hole in them that will match up with the holes on the number 1(?) cam caps (intake/exhaust). simply stick a 5mm punch or drill bit thru and you will have it at TDC
Craftsman sells a rubber strap wrench that is also very useful for this. It will fit around the outside of the sprocket, and doesn't cause damage to the teeth since it's made out of rubber.
Here's the set I have:
http://www.sears.com/sr/javasr...CRAFT
alterdcreations
Jan 24, 2007 11:45 AM
